NF7-s v2.0 problems!!!!!
thewizard1785
NF7-s v2.0
AMD 2600+ mobile & slk 900u
Corsair Ram
fortron PSU
9700 pro
Seagate 40GB
So I get all my hardware into my case hooked up properly and I turn on the system. It boots and indicates cpu identified at 600MHz. I realize that I forgot to hook up a floppy and so I turn off the system and add the floppy drive. I tried to boot the system again and the mobo would start beeping like an ambulance. I remove the floppy drive and try again and the same problem. So I make a checklist to make sure each and every single wire is attached properly. I do that and try again but no success. It sounds exactly like an ambulance.
What do you suggest I should do?
Your AMD mobile is a totally unlocked chip. (I would re-seat this chip in the socket and make sure it is in tight and firm)
You need to set it up in the BIOS to get it to show proper speeds.
I would also check the CPU cooler is making good contact w/ the chip and reseat the memory sticks as your MOBO maunual suggests.
Good luck
Had you unplugged the computer and grounded yourself before you opened up your case again? Have you tried reseating everything in the computer? After reseating, did it work? For myself, 90% of my problems have always been solved by reseating.....the other 10% however....
