NF7-S thermal issues
katarn444
My temps reported by the bios and windbond for the CPU are something rediculous like 84 degrees. At first I got really scared and turned of the computer and reseated the heatsink. Same thing, but as I was screwing around with it my temps went from 64 to 28 in about a second. The case temp is normal, so I am almost positive that it is reporting the wrong temp. The computer was overclocked but I put it back to stock. I have been playing games and the temp does not change and I have not had a crash yet. Does anyone have any experience with something along these lines?
Thanks for the help
katarn
I think I remember reading about the NF7S having some issues with some BIOS erroneously reporting the temps and a BIOS update fixing the problem. Might want to check into it.
Yea I had a similar problem and a BIOS update fixed it.
I think I have the newest bios verion but I will check when I get back home. Thanks for the suggestions.
katarn
