Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
altho i do own an NF7-S and love it i dont use the SATA-RAID function, its sad actually. now that thats been said i dont wanna sound like an ass here. but.....RTFM!
=b
~B1zz
EDIT: and if you dont have the mobo and/or the manual it can be found HERE for reference...;P
when you setup windows, when it first starts it says "if you have any 3rd party raid drivers insert them now" thats when you hit whatever "F" key it is and install them off the floppy otherwise windows setup will not see the SATA drive
