nf7-s revision question
skinlab
how can i tell if the nf7-s im getting is a revision 2?
i know on the asus a7n8x-dx it said rev. 1.04 or 2.0 between the 2nd and 3rd pci slots, is the abit the same way?
i wanna check which one it is before i buy it, so im gonna need to take a look at it in-store.
thanks.
FiZ
Yup. Not sure if it is between the 2nd and 3rd PCI slots but it is somewhere around the PCI slots, can't remember exactly where.
Phantum
Look here
The board that Newegg sells, is revision 2. But the serial sticker is by the PCI slots.
