NF7-S Rev 2.0 SERILLEL2?????
md262626
Hey how does this thing work? I added the SATA drivers that came with it when I freshed an install of XP Home. In the Bios I have the SATA as the primary boot, SATA enabled. What gives? Do I need to Disable the primary IDE controller? I'm not sure if installing this gizmo will help, but I like the smaller cables it uses for airflow. Any help would be appreciated.
I think you have to install the drivers for SATA when you install XP (hence the floppy). I think..
Does your SATA recognize the drive during bootup?
I am not booting off the SATA drive like you but I do have an IDE drive (my primary) on IDE0 and my second IDE drive on SATA1.
When I boot, the SATA controller doesn't seem to recognize that there is a drive even though XP can access the drive just fine. I wonder if it is related to that?
I am running the same MB as you, Abit NF7-S Rev 2.0 with the same Serillel2 convertor.
I had a similar problem...
Remember that your drive has to be set to master in order to use the serillel2..
For me to get it to work, I had to hook harddrive to IDE, install XP, then boot into windows on IDE, then install SATA, shutdown, then install sata drivers, then powerdown, put hd on sata adapter, then powerup. That is what I had to do, it might help you.
Good luck!
I have no problems with my particular Serial ATA/Serillel combo on my new NF7-S V2.0. The only problem that I have had so far in the few hours since installing this board was my M-Audio Revolution card wouldn't work even though the drivers were installed. But then I removed the card, and found dust on the edge connectors. I removed the dust, and then reinstalled the card. No problems since.
Here's what I've done so far with no luck. Tried installing Serillel2 on existing XP Home. I put the XP OS disc back in CD tray and changed BIOS to boot from CD RW. When OS booted I pushed PF6 as instructed and put Serillel floppy in. When asked to load other mass storage drivers I loaded the 3112 Silicon Image drivers for Serillel (this is with the IDE controlling the HDD). Powered down computer. Installed Serillel adaptor to SATA channel 1. Booted to bios and changed boot to SATA from HD-0. Enabled SATA in onboard peripherals. Rebooted. Got message Non Boot Disc, Please insert System disc and press any key. What gives?
Actually, you might have f***ed up (hosed) your Windows installation doing it the way you did it. The proper way of installing the Serial ATA driver on an existing Windows installation is to simply look at your Windows Device Manager (Click "Start" --> Right-click on "My Computer" --> Click "Properties" --> Click "Hardware" tab --> Click "Device Manager"). You will see an exclamation mark besides the line "Mass Storage Controller" (or something similar). When you do, double-click on that line, then click Driver tab (or reinstall driver button), and then put your SATA driver floppy into the drive. Do all of those steps with the hard drive still connected to the regular IDE channel, then shut down (power down) your system. Only then may you install the Serillel2 adapter, the requisite power cables, and the Serial ATA cable - between your existing Ultra ATA/100 or Ultra ATA/133 hard drive and the SATA1 port on your motherboard or controller card.
That said, I did an entire Windows re-install from scratch yesterday evening when I installed my new NF7-S V2.0 motherboard (with my new Barton 2600+ CPU and 1GB of DDR400 memory) - with my existing ATA/100 HD already connected to the Serial ATA port via the Serillel2 adapter, power cable adapter and Seial ATA cable. I have no problem whatsoever with the driver installation.
If you are not setting up a raid array... just install WinXP on the disk connected to IDE. Then once it is all installed, enable the SATA controller in the bios, reboot, windows will see a new device. Here you do "update drivers" for that device with the correct SATA driver.... 1.0.0.32 for NF7-S is what I use. Now once the driver is installed, power down, move the drive over to the SATA connection, set the boot device to SATA in the bios and reboot.. presto it should power right up.
Make damn sure you also add KB331958 from MSoft update to the system if doing anything on SATA to avoid corruption issues.
