Aug 6, 2004 #1 R rusty Limp Gawd Joined Nov 9, 2002 Messages 380 in the video settings it caught my eye that the agp bus was detected @ 4x....is this correct, and is there anyway to set it to 8x? nf7-s 2500+ barton corsair xms 2x256 pc3200 windows xp FX5900XTOC
Aug 6, 2004 #2 B BakedGoods Limp Gawd Joined Jul 23, 2004 Messages 312 Check ABit's site and see, it is an ABit board right? If your board supports 8x (which I think it does) then you should be able to crank it up either in the BIOS or using a program. If the board is not 8x then there's not much you can do.
Aug 6, 2004 #3 F FiZ [H]ard|Gawd Joined Dec 21, 2002 Messages 1,934 The NF7-S is a 8x capable board. You can change it in the BIOS.
