NF7-S 2.0 won't post
it makes these long 3 second beeps continously. The computer worked for over two years with no problem. I recently took a stick of ram out and put it back in. THats the only thing I have touched. I reset the bios, changed ram slots, tried the ram in another computer to verify it worked, changed the video card, unplugged everything except the cpu, ram, and video card. Checked for short circuits... nothing.
I believe the beep codes means its a ram problem right?
The meaning of the beep codes depends on the BIOS (AMI, Phoenix, etc.), but long beeps are usually indicative of RAM problems, yes.
First of all, try to get the most minimal setup working: place the mainboard on a non-conductive surface, install the CPU, HSF and hook up the PSU. Install an external PC speaker if the board doesn't have an onboard one. Reset the CMOS and turn the system on. It should complain about missing RAM.
Next, install a single stick of RAM and turn the system on again. It should now complain about a missing videocard BIOS (look up the beep codes if necessary). If it still complains about missing RAM, try alternating RAM slots and using different sticks.
