NF7-M and AthlonXP Mobile
Wolf-R1
I think I know the answer to this one but I thought I'd query the [H]ardness. :D
Just put an AXP-M into my girlfriend's NF7-M and it shows up as an unknown CPU. That doesn't bother me but what crossed my mind is that it's entirely possible that since the BIOS cannot detect what CPU is there that not all of the functions of the CPU will be accessible...the higher order ones such as 3DNow and SSE/SSE2 support.
Or am I just smoking crack? :p
I actually just built a machine based off the NF7-M and a 2600+ Mobile 35w proc. it defaulted to like 600MHz and stated it as unknown cpu. I hardcoded the multiplier and fsb and it still says unknown cpu....but it runs at stock speeds but at 200fsb.
you can check the SSE/SSE2 functionality by getting CPU-Z
That was pretty much the same that I got...runs fine when I manually set it. WCPUID 3.3 reports everything there I was jut curious really.
Only the DFI lanparty bios will fully recognize the name string of a mobile XP...The unknown string IS cosmetic since the designer of the mainboard never figured you'd put a mobile cpu in a desktop machine...The mobile name is simply not coded into the desktops cpu lookup table in the bios.
MD
You "can" get some modded bios' that will show it as a mobile, but its not worth it if thats the only reason your getting the modded bios ;)
