Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well, my fan finally crapped out on my mobo, it lasted longer then most..lol. I would like your guys opinion on what the best cooling would be to replace that fan? Slot Cooler? Not to much though. $5-15 range.
most of them have the push pins that go thru a hole in the motherboard and have barbs that open up on the backside to "catch" it on. Can be a real pain as you need to take the board out to squeeze the barbs together so the push pins will back out of the holes.
If you have a small pair of side cutters you might be able to get at the bottom of the push pins from the top side of the board and cut them. They are plastic.
