So I'm in the market for a new Nforce4 Ultra board, since I'm not going to be able to afford SLI anytime soon. I've been going back and forth on a couple motherboards and just can't decide. For this build, I will be using:
-Venice 3200+ or Opteron 144 or 146
-Centon 2 x 1 GB PC4000 (Samsung UCCC on Brainpower PCB, RAM is not yet released apparently)
-Seasonic 600W PSU
-7800 GTX
-3 HDs
-Thermalright SI-120 or Thermaltake CL-P0114 heatsink
Issues I need addressed:
1) I would really like a board with dual ethernet, but if I can't accomodate that then I will have to make do.
2) I cannot compromise on the 3 HDs, and I don't know if it's rumor or fact, but from what I've heard some Nf4U boards don't lock all their SATA ports, limiting the overclock.
3) I need to be able to overclock well. I don't need 350 HTT, but 300 should be doable.
4) I think I would prefer to use the Thermaltake CL-P0114 heatsink, since it seems to perform well and includes a quiet fan, which will help save some money.
5) I need at least 2 PCI slots free (for my sound card and TV tuner), and I don't want to have a 7800 GTX placed right up against that...room to breathe would be good, so I either need spacing between the slots or 3 PCI slots.
The obvious choice is DFI, but I'm hesitant for several reasons:
-The DFI requires 4 power adapters, which I know will end up being messy.
-DFIs seem to be pickier about RAM than other motherboards, and I don't know if it will accept my RAM or not.
-I will be using a Seasonic power supply which, while good, isn't a Powerstream or PCP&C and I don't want to catch flak for it if I need troubleshooting help.
-I don't know if the DFI will accomodate the heatsinks I chose.
-If it will accomdate it, can I put my videocard in the top PCI-E slot or will that not fit?
I really don't know where to go from here, can anyone help?
-Seasonic 600W PSU
-7800 GTX
-3 HDs
