NF200 Motherboard With Single GPU
It depends on the motherboard you are using. If you're using a board wired like the Maximus IV Extreme, the top PCI-E slot is connected directly to the CPU. Some other boards have to go through the NF200.
It will add some latency simply due to the design of having to pass through the chip, but I highly doubt that it is significant enough to matter.
