Child of Wonder
- May 22, 2006
Let me preface this by saying I have never worked on the Nexus 1000v before, outside of a short stint of setting it up in my lab then uninstalling it.
After being tasked with assisting a client with upgrading their VMware environment and Nexus switches, I've been going through the process in my lab. Cisco offers a great utility that allows you to input the VMware and Nexus version you're on and what you'd like to update to, then spits out the proper update order complete with links that document each step.
Unfortunately, Cisco's documentation is convoluted.
Here's the order of the upgrade:
Upgrade vCenter and VUM from 4.1 to 5.1
Upgrade VSM to 4.2(1)SV1(5.2)
Simultaneously upgrade ESX 4.1 hosts and VEM with custom ESXi 5.1 ISO that includes VEM version 4.2(1)SV1(5.2) using VUM
Upgrade VSM to 4.2(1)SV2(2.1)
Upgrade VEMs to 4.2(1)SV2(2.1)
My lab upgrade went fine until the last step when I upgraded the VEMs. Using the VSM to issue "vem upgrade notify" and "vem upgrade proceed" simply ends in an error in vCenter. I eventually ended up loading the vibs directly on the hosts and using esxupdate to install them, then running "vem upgrade complete" on the VSM.
How have you guys typically done the VEM update? Cisco's documentation offers a few options but I'd like to hear what people in the field have done that works for them.
I also noticed under Inventory - Networking the version of the Nexus VDS is 4.0. Is that normal or should it also update to 5.1 like any other VDS?
