Next Video Card Advice Please
Discussion in 'Video Cards' started by maxinflixion, Oct 22, 2015.
  1. maxinflixion
    maxinflixion Gawd
    537
    Apr 2, 2007
    I am currently running a Radeon HD7950 3gb.
    The main reason I want to upgrade is efficiency and noise.
    As long as the card has even a modicum of improvement performance-wise, I am ok. I just want something quieter that pulls less power.
    Does anyone have suggestions?
  2. a3venom
    a3venom Gawd
    695
    Mar 3, 2015
    GTX 970 since you want efficient.
  3. Zorlag
    Zorlag Limp Gawd
    272
    Sep 14, 2003
    He wanted less power use, not more. :)
    There´s nothing in the market that would exactly fit that criteria.
    960 is bit too weak outside 1080p, but it has a low power use.
    970 is reasonably more powerful, but uses somewhat more power (and there are few models with awful fans so beware those).
    380 uses similar amount of power but is only slightly better in performance outside tesselation.
    If I were you, I would hang on to your card until next year. Downvolt it and find a stable downclocked state for it. Then build a quiet fan profile. You will be surprised how much you can reduce the power use without hitting your FPS much. Then next year, buy a new card with a chip that is made with FinFET process and uses mature HBM 2.0 stacks.
  4. a3venom
    a3venom Gawd
    695
    Mar 3, 2015
    Pretty sure the 970 uses less power than 7950, what are you talking about? do you even lift bro?
  5. Zorlag
    Zorlag Limp Gawd
    272
    Sep 14, 2003
  6. a3venom
    a3venom Gawd
    695
    Mar 3, 2015
  7. noobferguson
    noobferguson Limp Gawd
    462
    Oct 6, 2013
  8. Samson4EiT
    Samson4EiT [H]ard|Gawd
    1,503
    Nov 11, 2008
    Sorry you are the one lacking the knowledge.... do you even do any research?Power consumption charts
    Nvidia claims and talks about having a target of 150w, but in reality its closer to 200w depending on board. In no situation do I see the 970 drawing less power than the 7950 though.
    EDit: So OP, it's pretty much what Zorlag said. There's not really any card more powerful that's the same power or less unfortunately.
  9. limitedaccess
    limitedaccess [H]ardness Supreme
    7,493
    May 10, 2010
    Which 7950 do you specifically have? What is it's vcore and clockspeeds? Have you modified it at all (clockspeeds or power limits)?
    If he has a later boost edition Gigabyte 7950 it could be voltage locked at 1.25v which would make it have much higher power consumption than the launch references models.
    In terms of straight power consumption though I don't think you are going ot gain much by going to a GTX 970. Noise possibly depending on the specific board and it's heatsink.
    The only real significant drop would be going to a GTX 960 4GB .
  10. wantapple
    wantapple Gawd
    601
    Jan 8, 2012
    i dont think thats a good upgrade... going from 3Gb to 3.5GB card makes no sense....
  11. cageymaru
    cageymaru [H]ard as it Gets
    19,814
    Apr 10, 2003
    Thanks for the link. Seems like the OP isn't going to find a solution unless he's willing to run a slower GPU.
  12. Cool Vibrations
    Cool Vibrations Gawd
    660
    Oct 29, 2008
    "Hurr durr AMD sucks, nothing new, their whole lineup are rebrands!"
    "7950 is NOT a 280, they're totally different, you're stupid bro."
    http://www.guru3d.com/articles-pages/gigabyte-geforce-gtx-970-oc-mini-itx-review,7.html
    http://www.techspot.com/review/885-nvidia-geforce-gtx-970-gtx-980/page7.html
    Pretty sure you're WRONG.
  13. Zorlag
    Zorlag Limp Gawd
    272
    Sep 14, 2003
    I hope he has a model that can be downvolted. I have R9 280 here myself and I managed to make my room considerably less toasty by simply going into basic 280 settings which is 850 core and dropped the voltage as low as it went.
    And I apologize for my inappropriate tone. I hope e3venom can do the same for me. Deal? I need to practice what I preach more carefully from now on and keep out of these silly word fights.
  14. a3venom
    a3venom Gawd
    695
    Mar 3, 2015
    ^ it's all good man, i am just internet gangsta.
    but you are right on downvolt, i do that to my r9 290 and it uses 180 peak on GPUZ while it would do over 220 earlier.
  15. Zorlag
    Zorlag Limp Gawd
    272
    Sep 14, 2003
    Wonderful. It´s all good now, mate. Have a good day.
  16. a3venom
    a3venom Gawd
    695
    Mar 3, 2015
    But when i said the 970, it is because it uses more or less the same power and is rated much lower, and is a significant upgrade in terms of perf for the OP.
    a 960 will be a sidegrade at best.
  17. Remon
    Remon Limp Gawd
    352
    Jan 8, 2014
    If you're going for efficiency, wait for the next generation of cards.
  18. ManofGod
    ManofGod [H]ardForum Junkie
    10,902
    Oct 4, 2007
    What did you use to undervolt it with? How low where you able to go and how much lower did you have to underclock it?
  19. a3venom
    a3venom Gawd
    695
    Mar 3, 2015
    MSI Afterburner to UV, i can go upto -50mv with stock clocks and - 38mv with 1000/1300 (which i used)
    I flashed the 390 bios with modded mem volts on another instance and my AB shows 1.17 voltage in the overlay while gaming - and i am at 1010 / 1500 on this particular bios. ( this is the one i really like to use )
  20. maxinflixion
    maxinflixion Gawd
    537
    Apr 2, 2007
    My current card is a Gigabyte GV-R795WF3-3.
    I would prioritize noise over power consumption in my needs list.
  21. limitedaccess
    7,493
    May 10, 2010
    You are running all stock?
    What you can do is try to adjust vcore lower and then using a custom fan curve with something like MSI Afterburner. You can then ride this out until the second half of next year.
    In terms of a real "fix" the only option at the moment is the GTX 960 but that you aren't going to, out side of specific cases, get any real performance gain (may be lower as well depending on work load).
    In terms of purely noise then this does open up more higher end options, assuming your airflow setup can overall handle the additional heat load, as some of the newer custom solutions are improved even with higher power consumption cards.
  22. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    6,287
    Jan 17, 2005
    Do not jump from 3 to 3.5GB.
    Get a card with a big performance boost that only eats a bit more wattage.
    980, 980ti, r390X.
  23. a3venom
    a3venom Gawd
    695
    Mar 3, 2015
    ^ Exactly, .5 gb is not a good upgrade.
    I had 270x 4gb and upgraded(sidegraded) to a GTX 980 4GB, no noticable difference in games and i wasted so much money.
    More GB = Better
  24. KickAssCop
    KickAssCop [H]ardness Supreme
    6,576
    Mar 19, 2003
    Whatever you must be smoking should be good if you are unable to discern difference in games between a 270x and a 980.
  25. noobferguson
    462
    Oct 6, 2013
    The sheer outlandishness of the statement--in light of the informed tone of his earlier posts, along with the repetition for punchline effect--might imply the aim of being sarcastic.
