2500k
P8 Z68-V/Gen3
8GB 1600Mhz 9-9-9-24 2T
I've been working on finding the lowest voltage @ 4.3 which seems to be @ 1.285. I tested it again @ 1.280 last night for a half hour of Prime95 at both FFTs 1344 and 1792 with no failure. Before I went to sleep I put it on blend which I wont know how it went until I get home from work.
My question is, I want an OC @ 4.5Ghz. Should I just set the multi to 45 and try to find a stable voltage before finding the lowest stable Vcore at 43 and 44? Temps will be a concern during the summer and right now they are hitting around 52 tops with a pretty cold ambient room temp (unsure atm).
Also, my LLC is set to Ultra High. Any suggestions for determining what I should set it at? I've read ASUS recommends Ultra High for average OC's and Extreme for probably 4.8+. I obviously just want to find the lowest possible Vcore @ 4.5.
P8 Z68-V/Gen3
