next match!
First link is broken. Zippy out of the other two has my money. "Let's get it on!"
The zippy has 50 less watts and 4 less amps on the 12v rail. Any specifics as to why it would win the duke out.
from what i understand they make pc power and cooling.. not all ratings are the same.. some are under rated.. some pump up the 5v to get a higher rating.. and some outright lie in their ratings.. but i understand zippy to be a very solid under rated psu.. get a 2nd opinion on this though.. cause i just rememebr reading it a while back.,..
I think I'd go Zippy, despite my own attachment to Fortron/Sparkle, though they're both good units. IIRC Zippy has a longer warranty, 3 years vs. 1 year, though you'd be unlikely to need it on either unit.
Keep in mind the Fortron unit is rated at 550w at 30 degrees, and 500w at 50 degrees. Zippy rates and tests at 40 degrees for every unit. These two are probably pretty evenly matched in total power output.
Basically for the reasons everyone else has said.
