Next [H]ard box contest setup.....
I have a ex360 xspc rad, xspc water block, and a pump (maybe danger den I can't remember) all of it has 1/2 barb fittings attached. I also have some misc lengths of black 7/16 tubing.
I'm almost sure that I have the 1366 bracket for the block, I'll have to pull the parts from storage to be 100% sure.
I'll donate any/all of the listed parts if it's still needed.
Kendrak this guy has 2 HAFs (a 932 and a 922m) for $75 and $50 shipped respectively if you want to look into putting it in a case, those are both a smoking good deal. Just food for thought. Also I will see I can donate a few bucks after I get paid and pay those pesky things called bills.
A 2x120 may make the rear fan unusable but not the end of the world.
I have used the V3 case and it was pretty flimsy but not bad for the price. I imagine the v4 is more of the same. It looks almost identical inside.
The DD 120 rad I sent is pretty hefty it weighs more than my 2x120 swiftech so it could probably handle a 920 on its own. I never had a chance to use it so i cant say for sure. Based off holding them alone i would say it weighs about 3 times as much as an h50.
For not too much more I would vote for the CM HAF 912. No 2x120 rad option but you could always pick up a radbox for $20 or so and mount a rad externally.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
I think I have a radbox I could send if you need it. Just let me know Kendrak. You know a 2x120 could fit on top of the 912 i believe.
this is how I set up my 480 rad on my HAF912 .... :D
I think i will leave it to the ultimate owner....
They might not like duck tape as much as me :p
Dookey is right, i didn't look close enough. I thought the top fan was a 120 but its a 200 and has mounts for 2x120 fans on top. You can see it if you look at the top down shot on newegg.
My bad.
I have a coolermaster storm which I believe is about the same dimensions I believe the 912 is 1/2" wider. I installed a EK cools stream XT 120 single radiator and EK HF water block on the inside of the case where the 120MM rear fan goes I put the rear fan on the radiator on the inside. I then put another 120MM fan on the outside of the case for a push pull. That rig is running a 970@ 4.275Ghz in a room with 70F ambient temps it runs between 68C and 75C folding bigadv 24/7 so you could get away with a single 120 radiator on the inside and have a nice clean install.
I have a Thermaltake Armor+ that I managed to fit a triple radiator in (with some slight mods, but nothing permanent). It will do a double radiator easily. The only problem is it is MASSIVE and weighs 35 lbs. I believe I have most parts but for the cost of shipping I will donate it.
Any thoughts?
Any thoughts?
I think you need to find how much shipping is.
That is true......
I was at microcenter a bit ago, and going to pick up a case, but the one that looked good was OOS :(
Yes I am partial to the HAF as well I think it is a good choice and you cant beat the shipping cost.
OK, I grabbed 2 of them.
I'm probably going to do a quick test of the WC stuff and pack it in the case to ship.
The air cooled system I plan to assemble, run, then ship, when It's time comes.
