maverick786us
- Aug 24, 2006
When is the next generation MacBook Pro 15 with Skylake processors coming?
When Tim Cook stands on a stage and says so.When is the next generation MacBook Pro 15 with Skylake processors coming?
I think its more than an year now. Buy now Apple should have implemented skylake processors in its 15 inch MBPr just like the way they did with its 13 inch little sister
Isn't improved power efficiency the number one priority in laptops? Any improvement in battery life should've made it worth it to them to make the switch.The 13-inch model uses Broadwell, not Skylake, and it hasn't been updated for about a year. I'm guessing that Apple is holding off simply because it doesn't see an appreciable gain from Skylake right now.
At this point June isn't that long to wait anyway. April is done. Basically 6-8 weeks. Time is flying for me. Will be summer in a hot minute.
typically when they release something "new an innovative" its old tech, so when you see enthusiasts with 8th gen and off the shelf stuff as 7th gen, the apple line will be releasing the latest and greatest as 6th gen
I've been back and forth on buying a current ThinkPad but will probably end up buying both when the correct specs are available. InfoSec leaves me needing pretty strong hardware.
On that note however, the Macbook upgrade seems very underwhelming. I'm not sure if the USB C on the new Macbook is Thunderbolt 3. I didn't see that mentioned in the press release. But if it's not, I hope it's not an indicator of what's coming up. I sincerely hope that what I said in my previous post comes true: that they move to USB-C/Thunderbolt 3 on everything and upgrade their displays. If not for me, than for Apple's sake. I think their Displays in particular have been lagging. They need to up their game and quick.
It's not Thunderbolt 3 -- just USB 3.1 gen A.
Also, I find it a bit odd that you say Apple is lagging in displays, since that's arguably its strong point. Many of the higher-res displays have gotchas. That 3200x1800 IGZO display? Sure, it's sharp, but the colors are off. That 4K display is amazing... and it shrinks the battery life to 5 hours. That and Windows still has problems with high-DPI app scaling that Apple solved in 2012. I don't want to see Apple go to higher resolutions unless it can maintain accuracy and longevity, and it's not as if the current displays look bad.
That's a shame. There was a big opportunity missed there. They made that not an option for pros that need at least 1 Thunderbolt port for connectivity.
They are unequivocally lagging in displays. They have a 5k iMac and a 4k iMac. Both which look fantastic. And now run in 10-bit, which is a big deal for professionals.
But their 27" display? Still 2560x1440. Their 20"? Still running at 1080P. If you buy a Mac Pro and you need to view and work with video in 4K, Apple provides ZERO options. That's lagging. So your only option is to go to EIZO or NEC. That isn't a bad thing, as both NEC and EIZO provide professional level displays in terms of color accuracy and output. But that's bad for Apple if they want to capture that portion of the market.
I should note that my perspective is based around using this as a professional. I don't want an ultra-wide display. That's not useful for me in a professional (video and photo editing) environment. The displays on the iMac work more than well enough, but they aren't stand-alone.
To be fair, Apple hasn't really pitched the 12-inch MacBook as a pro system. I wonder if it'll show up in the next revision, though.
Oh, desktop displays -- sure. That, I think, hinges on there being a newer Mac Pro. Apple would likely want to make a 5K stand-alone display, and that would require Thunderbolt 3. WWDC, maybe?
For reference: Apple hasn't made a sub-27-inch stand-alone display for a while now. There's only the 27-inch Thunderbolt Display.
I would take a guess to say that the reason it's not there is because they would have needed a separate thunderbolt controller and were already stripped for PCB space. The fact that the IHC they used supports 10GBP/S USB 3.1 but they decided to (again) only use 5GBPS to save on space would say something.True, but then it's the only "consumer" level machine that doesn't have it. I wouldn't call the Mac Mini a "Professional Level" system either, but it has Thunderbolt.
Couldn't agree more that they've let their stand alone displays dwindle, although admittedly their demand I imagine has similarly dropped to nothing. The cinema display was not intended to be paired with the mac pro, it was actually designed for the rMPB's as a dock for professionals, and, at the time TB was the only port that could shift the amount of data for the extra ports it has. it's pure coincidence and response to the slow adoption of HDMI 2.0 that Display port and TB as display connections have taken off.They are unequivocally lagging in displays. They have a 5k iMac and a 4k iMac. Both which look fantastic. And now run in 10-bit, which is a big deal for professionals.
Let's also be honest, although it would have been nice, there's nothing out there today that can saturate even a 5GBps bus beyond an external SSD drive, and they're not exactly flying off the shelf yet.
The display remember, has an integrated 'dock' of USB ports, SD card reader and gigabit ethernet. it was designed to be a hub for someone to connect their laptop and 'dock' with peripherals. Not, as a monitor for the Mac Pro. The fact that there's been an explosion of much cheaper TB docs and no one in their right mind would want a sub-par screen with an integrated dock that has outdated USB ports is sort of a mute point now. Mac pro's and Mac Mini's are simply the lowest volume products out there that actually need an external display, and only the mac pro could even comfortable run a 4K panel. I'd imagine Apple isn't exactly clamoring to make a new $1000 4K monitor when the people that could benefit from a refreshed cinema display dock--laptop owners-- have IGP's that can barely handle the internal's display resolution.
New, thinner Macbook Pros will reportedly have an OLED touch bar
Looks interesting. I am not sure if its worth to wait till late 2016 for that flashy screen?
