next gen mobo's, Still ATX?
gemini8026
curious, is it worth buying a fancy new case? IS the next gen mobo's out soon a new standard, or will we see ATX around for a while on strandard mobo's?
Of course no one knows for sure, but I would bet that you will see both ATX and BTX mobos made for the next few years. With BTX slowly taking over. So sure, if you see an awesome case and really want it get it. Just know that by the end of this year, the new rave will be BTX.
I'd wait in getting a fancy new case. BTX is going to rape the ATX market for the newest parts.
Oh Sods law.
Every since AGP Vidcards have been the wrong way up. and just as PCI-E is comming in to mainstram BATX come along and flip the whole Fing thing round again. Will we ever have a chance to get a vidcard where the core faces up.
Since you obviously just buy video cards based on how pretty they look, why don't you just hang it on the wall rather than using it?
Well, wouldn't it be nice for the heat-generating part to face up, since heat rises?
That's why there is a fan on the video chip. All things being the same (airflow, case temp, fan etc), a card facing down and a card facing up would cool exactly the same.
If one of the advantages of BTX is larger size, among other things, then EATX users have had that advantage for a long time.
unless there will be casefans near the top of the case it looks like the ram might get a tad bit hot.. sittin at the top of the case above the cpu and all. running at like 533+mhz too
Actually, the BTX is designed around Volumetric Zones which try to contain the heat producing elements of the computer, including the CPU, memory, video card, chipsets, etc. in an area in which the temperatures are controlled by a Thermal Module. One of the primary design considerations for the BTX form factor was environmental control.
The actual specification is below.
The BTX Specification 1.0
intel pretty much said that they weren't going to be pushing BTW as much this year as planned, and it will be focused on next year.... unfortunately I don't have a link to that article, but that's the plan... so, buy yourself a new case..
besides.. just because intel is going btx, doesn't mean amd will be right away... who know how it will turn out.. go buy a new case, you atleast have another years worth of harder comming out that will work in it..
No I Don't I buy for performance per £ (9600 Pro currently)
however If the core faced the otherway up it would be more effecient at cooling the card and teh dispenced hot air from the core would not have to pass the ram on it's way out teh case.
It's still going to be ATX for the next year. Starting 2nd quarter BTX will start coming out. It will be about 18 months until BTX is fully adopted by the industry.
