- May 9, 2008
I'm getting 11MBps write and ~9.8 MBps read from the array. The NIC is a Intel server dual port gig card is getting a link speed of 100 Mbps. e1000g0 and e1000g1 are detected with only g0 hooked up. My understanding it that the system looks through the list of "advertised" link speeds and picks up the first one available. Far as I can tell it should be 1000 mbps full duplex but it's not taking it.
SunOS nexenta 5.11 NexentaOS_134f i86pc i386 i86pc Solaris - NexentaCore 30 Hardy 804b134
My list follows:
The switch is set correctly and I have switched cables. I really just use this as an appliance via Napp-it and don't know Solaris commands at all.. Due to the battle I had initially getting the network to work a couple years ago I really don't want to break anything trying random internet commands to try and force the link speed. Can someone help me out on what I should try next?
Thanks
My list follows:
Code:
ndd -get /dev/e1000g0 ?
WARNING: The ndd commands for datalink administration are obsolete and may be removed in a future release of Solaris. Use dladm(1M) to manage datalink tunables.
? (read only)
adv_autoneg_cap (read and write)
adv_1000fdx_cap (read and write)
adv_1000hdx_cap (read only)
adv_100fdx_cap (read and write)
adv_100hdx_cap (read and write)
adv_10fdx_cap (read and write)
adv_10hdx_cap (read and write)
adv_100T4_cap (read only)
link_status (read only)
link_speed (read only)
link_duplex (read only)
autoneg_cap (read only)
pause_cap (read only)
asym_pause_cap (read only)
10gfdx_cap (read only)
1000fdx_cap (read only)
100fdx_cap (read only)
100hdx_cap (read only)
10fdx_cap (read only)
10hdx_cap (read only)
lp_autoneg_cap (read only)
lp_pause_cap (read only)
lp_asym_pause_cap (read only)
lp_10gfdx_cap (read only)
lp_1000hdx_cap (read only)
lp_1000fdx_cap (read only)
lp_100T4_cap (read only)
lp_100fdx_cap (read only)
lp_100hdx_cap (read only)
lp_10fdx_cap (read only)
lp_10hdx_cap (read only)
link_autoneg (read only)
tx_bcopy_threshold (read and write)
tx_interrupt_enable (read and write)
tx_intr_delay (read and write)
tx_intr_abs_delay (read and write)
rx_bcopy_threshold (read and write)
max_num_rcv_packets (read and write)
rx_intr_delay (read and write)
rx_intr_abs_delay (read and write)
intr_throttling_rate (read and write)
intr_adaptive (read and write)
adv_pause_cap (read only)
adv_asym_pause_cap (read only)
Code:
DEVICE LINK MEDIA STATE SPEED DUPLEX DHCP IP NETMASK MAC MTU VLAN AGGR
atge0 atge0 Ethernet down 0 unknown manual - - no such interface - todo todo
e1000g0 e1000g0 Ethernet up 100 full manual 172.16.12.72 255.255.252.0 0:15:17:c3:a9:26 1500 todo todo
e1000g1 e1000g1 Ethernet unknown 0 half manual - - no such interface - todo todo
Thanks
