Nexenta does it support WOL?
nbat58
I have been trying to find a way to anable wol in Nexenta whithout success, just need to change the ethernet card settings to allow wake on lan.
Does anyone know if this is supported, I would appreciate your guidance if you are aware how this is done.
Many thanks.
WoL has nothing to do with software and is purely a hardware thing.
I understand that most is handled by the hardware and bios adjustments but how would you change the NIC driver settings to accept magic packets in Opensaolaris/ Nexenta, in a linux environment you would use ethool to adjust the NIC driver settings, in Nexenta I can not find any adjustmets to magic packets in dladm.
When running FreeNAS the WOL was working flaulessly and now with Nexenta it does not, I have not changed any od the bios settings between the FreeNAS and Nexenta installs.
