Newly built system wont turn on :(
LawGiver
i just built a second system here are the specs:
e6320
DS3 V 1.3
2gb g skill
750w silencer quad
every time i press the power switch everything turns on for an instant, maybe a half second, then turns off again. never had this happen before, but im sure others have. anyone know whats going on?
Check your wiring, it sounds like you might have some wires crossed. Or a naked wire maybe expossed.
i noticed the motherboard speaker connector was chewed on and one of its pin wires slightly exposed, but i did not plug it in, could this be the problem even though its not plugged it?
i dont mean on the motherboard, i mean the connector that runs from the case to the motherboard.
wow looks like brand new power supply is DOA. put in ps from other system and it turns on fine, think ill go silverstone this time.
Strange, don't hear about power supplies DOA very often, especially such high-performance ones. SOL on that one
Did you try plugging the old one back in? Maybe it was just loose and when you plugged in the PSU from your other system it was just in place and tight.
Have you tried unmounting your mobo and powering it on while it's just sitting on the table? Sometimes the motherboard might be short circuited due to improper mounting.
yeha i did thats what i thought too at first but same thing happened.
a little unrelated, do you guys know why windows shows im running 6x multiplier when infact its 7x?
Should be a BIOS setting to disable all that, wait states, etc.
Call wherever you got the Silencer from, get it replaced, and if they won't do it PC Power and Cooling, directly. Don't buy something else. Nearly every company gets bad stuff out occasionally -- hell, I've had 2 P4's show up DOA.
