Aceharding
- Dec 21, 2006
Alright, I've built a computer from scratch before and it worked fine. But when built another computer for a friend, it won't start up bios.This is what I have:
Intel Celeron D 336 Prescott 2.8GHz LGA 775 64-Bit Processor w/ Execute Disable Bit
Linkworld F3131-C2628-P4 Black/Silver Steel ATX Mid Tower Computer Case 400W Power Supply - Retail
BIOSTAR PT880 Pro-A7C LGA 775 VIA PT880 PRO ATX Intel Motherboard -
pqi POWER Series 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) Desktop
Western Digital Caviar SE WD1600JB 160GB 7200 RPM IDE Ultra ATA100 Hard
MadDog 16X DVD±R DVD Burner With 5X DVD-RAM Write Black IDE Model
GeForce 4 Ti 4200 AGP 4X/8X
I put in the proc and the heatsink/fan on just fine, I put in the RAM just fine, I put in spacers and hooked up the DVD Drive and the Hard Drive on the same ribbon connected to IDE port 1 and hooked up the floppy. I set the jumpers correctly and turned on the computer with everything connected. No Video output...
The all the fans are spinning. The CPU fan, the Video Card fan and the case fan but no video output. I can't even see BIOS. I tried switching to a PCI ATI video card but still the same thing. I noticed on the front of my computer case that my floppy drive and mt dvd drive's light are on so I tried pressing eject on the dvd drive to see if it would spit out the tray, but it doesn't.... but the light is on... and won't turn off.
Any suggestions please?
