newly built... choppy video
bounds
Hi Everybody...
Well, I've been out of the PC building arena for awhile, and have decided to get back into it... (Doom III looks fun!)
Well, here is my setup:
AMD 3500+ 939
K8N Neo2 Platinum Motherboard
1 GB Corsair value select ddr
ATI 9800 pro
Seagate 80GB SATA HD
Pioneer 10X dvd
with Windows XP home edition and service pack 1a
I dont have any games yet, so just as a test i tried to play a dvd, and it plays very choppily. both audio and video. I am just using the motherboard on-board audio. Could this be the problem? I am stumped, but I assume an ATI 9800 pro should be able to handle dvd decoding. Is there a hardware decoding setting that I am missing??
the other problem doesnt have to do with video... Every other time i turn the PC on, it freezes at the user select screen. the mouse pointer wont move and the keyboard wont respond. I reset the PC and everything works fine. This happens every time i turn the PC on.
Any help will be greatly appreciated.
Thanks a lot!
K.C.
your random freezing problem is also probably bios related. are you running your bios settings at setup default???
when i first got the board i left it at defaults and couldnt even install windows without a freezeup.
what i had to do was go in and disable stuff i wasnt using and actually tighten ram timings and a few other things
the defaults loaded like some sort of 4449 settings and the ram/cpu didnt like those when i switched to 33310 they were stable.
I had the same choppy DVD video/audio problem on two machines. In both cases, the problem was solved by enabling DMA mode for the drive's IDE controller channel.
