Hey all
this is a long term project ( tech never ending ).
I want to setup an 8 drive raid that can handle 1 or 2 drives being down at a time(raid 6 i think right ?), I would like to have the option to replace/upgrade the drives like the drobo can ( is there a raid level that supports this?), but I don't want to spend 1600$; which is what a drobo 8 bay cost, when I can build a raid computer for well under 800$ ( minus hdd cost) depending on how I build it.
at first for testing and to get familiar ( I plan to use a linux based os ) I am going to use 3 250gb and 2 500gb drives. then I will add whatever controler card is recommend and restart the raid, then once I feel comfortable with the os, raid controller, and settings I will start to replace the drives with what ever is the current price per gig leader ( 1.5tb now i think )
keep in mind I have not used a raid for 4 years, and even then it was a cheap 2 drive raid 0 on my built in raid controller. ( had a scsi raid way back in the day also )
what I would like to know is what would be a good card to control the raid, is adaptec still a safe bet or are there better cards out, also what would be a good hdd to work with, I was thinking the WD green line but again I am not sure.
any help would be nice
Thanks
Bob
Thanks
Bob
