Hi,
I have a Core 2 Duo E4600 in my machine. With the stock fan the idle temp was around 35C and 50-60C full load.
I have replaced this with a G-Cool lite HSF and now th temperature is 19-25C Idle. When I load up "core temp" it shows different temps for each core eg. Core 1 = 22C Core 2 = 19C. Is this normal, or have a not applied the thermal paste correctly? Are there good temps or should i remove the HSF and re-apply paste?
also while im here, will this cooler be adequate enough for me to overclock this CPU to 3GHZ?
Thanks
Thanks
