Newest watercooling setup... pictures
noteworthy
Just wanted to post a few pictures of my latest work on my computer.
Running:
Gigabyte UD5 Motherboard
GSkill 1600 Memory 6GB Kit
i7 920 D0 Stepping @ 4.2 ghz
Sapphire 5870
Corsair HX1000 PSU
Generic CD/DVDRW Drive
1xRaptor 150GB
1x500 GB WD
1x640 GB WD
I bought a coolermaster haf932 off a guy on these forums for $95 shipped with everything. It came in new condition. Never seen used hardware come so well packed and complete/clean. Painted the inside of the case.
Bought:
XSPC reservoir for my DDC Laing Pump
UV Reactive Red Tubing 3/8" ID
White Cold Cathode
I've very pleased with the result. Pretty stuff.
No video card? Does the tubing get in the way? Also I noticed from the picture you have a Gamecon 777 and you taped the connections. I have recently started to notice strange distorted noises coming from the headset and I have had it for about a year. None of the connections are lose, but when you tap the volume controller it creates more of these distorted noises. Have you experienced something like that too?
I haven't taped the connections. That's stock.
Video card is in on the last pic. not earlier when leak testing.
The connections taped are the fans from my radiator to the fan controller.
Ahh I see.. the parts that are red on yours are black on mine... just assumed it was tape
Actually I regret that - pointless. It had decent temps with the stock cooling. Did get a 15-20C lower with mobo blocks but other then that no other advantage. The crucial stuff is on the cpu anyway with the i7s.
