Newer/different model # be good for Raid 0..almost same drive
SavageAcE
Hi Well I got a Seagate
ST3750330AS Barracuda 7200.11 SATA 3Gb/s 750-GB Hard Drive.
I been wanting to do Raid 0 for a while so I was looking for some of the same drives as mine,it turns out they are deactivated but I found one online from other world computing. So I ordered the drive which was the same model number as mine. Well I got an Email and it turns out Im getting a newer model which is the Seagate ST3750528AS Barracuda 7200.12 SATA 3Gb/s 750GB Hard Drive.
I called Other world computing to tell them and they basically said that Raid 0 should work out fine but I have heard the Raid 0 works better with the same harddrive.
Here's the links to the drives...The ST3750330AS
http://www.seagate.com/ww/v/index.jsp?vgnextoid=1cd981f8c0f43110VgnVCM100000f5ee0a0aRCRD#tTabContentSpecifications
The newer drive....ST3750528AS
http://www.seagate.com/ww/v/index.jsp?vgnextoid=f6082d0ca8dce110VgnVCM100000f5ee0a0aRCRD&locale=en-US#tTabContentSpecifications
As you can see their basically the same in every aspect except weight and the power they use.
So Im wondering if I use this drive for raid 0 what will be the problems?...will it be harder to setup?Will performance be effected?
Thanks for your help.
Performance will be effected but with those two models so close in specs to each other I doubt it will be noticeable. Even with two of the same model the writes/reads are not always synchronous anyway, the controller has to handle all of that.
I say go for it if you really want to, personally I am not a big fan of RAID 0 but that's because I have never seen one NOT fail eventually.
Why will performance be effected?sorry Im a n00b,I want to learn.
I have the option of actually sending back the drive for my money and trying to look for the exact same model number as mine....but it sounds like the performance will be very similar though.
I found the article comparing the drives....it seem like theirs some differences,I wonder if this will factor alot in the raid http://www.bjorn3d.com/read.php?cID=1526&pageID=6564
