Yes. As long as you have Win7 professional or greater you are fine.Isn't there a RAM limit on certain versions of Windows?
But I assume having 48GB RAM (although working) on home computer is very overrated.
Yep, had the same experience two years with G33 and 4GB DIMMs, and using 8GB DIMMs in my backup G45 rig now (Core 2 Quad).Don't see why not. Even though a mobo isn't specced for higher than X dimm density, it's usually possible to go higher when higher density ram is released, right? Guess it might be mobo specific whether these work or not though.
$405 for 48GB is anything but a fuck load. That's like $8/GB.
Of course - running that much RAM without any ECC basically guarantees data corruption eventually.
