Newegg: Open box motherboard thread again
Potatocodone
Yes it is another open box motherboard from newegg thread however I am just curious when was the last time someone actually receive any accessories?
I know generally most open box motherboards come with pricey shipping and overall not worth buying it but out of a few dozens there is one or two open box deals worth considering.
However the past 27 open box motherboards I bought all of them came in a brown or white box with only the anti-static bag as the only accessory. I have yet to come across any open box deals that has come with any accessories :(.
Although it is a crab shoot on accessories I thought by now I would see at least a SATA cable or hell even a floppy cable to just tease me.
I am just curious on how are other members here with their luck on open box deals.
I bought my current ASUS Rampage III Gene Open Box. Received everything and looked brand new, still had the plastic on the heatsinks and packaging was sealed with I/O shield. The reason why I got all that stuff is because I bought it when they first started to show up open box. After they've been up for a while, I think Newegg runs out of accessories to take from other returns, so some people don't get everything. Just try to buy a open box when a new motherboard is released. I wouldn't expect the older boards to have accessories.
I just wish they'd have the I/O shield. I can deal with no SATA, power, etc. But the I/O shield is needed (if you want the back to look nice and have good access).
Also, not to mention it's needed for shielding from electromagnetic interference. =]
In the past I've snagged both a KN8 SLI and a P5Q Pro as open box deals on newegg (and both nearly half off). The KN8 came with pretty much everything, I/O Shield, Drivers, Cables etc. The only thing missing was the manual. The P5Q came with an I/O Shield and cables and the case connection extenders, but nothing else.
Sure, it's nice to get accessories, but for most of us it's not a big deal. You can (and should) download any software/drivers you need. Same goes for the manual... and who among us doesn't have 80 billion cables and connectors of all kinds cluttering up a drawer or box somewhere? It was nice that I got some accessories with the open box deals, but honestly, I would have been perfectly fine without them. For someone doing their first build or is generally inexperienced with computers, then it's probably best to stay away from open box deals. For the rest of us, it shouldn't be a big deal.
You know, I've had systems where I didn't use an I/O shield (usually a problem with the case) and I've not noticed any difference. No interference, no nothing. I've heard tell of MBs that require them for grounding, but I've never actually come across one. In most cases, as long as you are gentle since there is less support for the connections, you are fine without one. You know, as long as you don't mind the unfinished look. It can get a little more dusty than usual if you are using the rear fan as an exhaust though, unless you have a positive pressure system going.
How thorough has your testing been? :)
A while back I grabbed an open box ASRock K10N780SLIX3-WiFi. The only open-box product I've ever bought from newegg. To my pleaseant surprise, it came with ALL accessories: backplate, HDD/ODD/FDD cables, and everything in between. It was like somebody opened the box and then closed it and returned it. The accessories were sealed in their bags.
Guess I'm just lucky. Eventually I got the board that replaced working again, and sold the ASRock to a friend for cheap.
ive gotten 2 open box mb from newegg. my p5k and a nforce4 sli 939 board. both came in original boxes with all the accessories.
i got one open box MB from newegg and it came with everything.
the second one i got only had the MB and I/O sheild
interesting news. I was always looking at those open box deals, but now this will make think before buying.
eeeh most guys here run cases with giant plexi glass windows...you guys are way overthinking it
I got an open box Asrock x58 extreme for cheap with my current build, it arrived with everything inside.
Picked up a MSI 890GX-G65 for $99 Open Box. I got lucky, it came with all the parts/accessories and it's been chugging along fine in this micro I'm using for PDX lan this weekend.
I bought an Asus M4A79 Deluxe and P6T6 WS Revolution open box from Newegg and had positive experiences with both.
The M4A79 came with all the accessories in the retail box, and the P6T6 even came in a sealed RMA box from Asus with an RMA number that came up showing it being completely replaced--so essentially a brand new board for almost half off.
All mobos are open box, none have a factory seal....
I don't see why you have to take the literal meaning.
Everyone else understands what an open-box motherboard means.
So take your dots back. Thank you.
I guess what makes me leery about open box is the why it's an open box.
I need the I/O shield so the RFI will be reflected out the acrylic window and into my cold leg.
Your lack of faith in human stupidity is disturbing.
The open box deals I've bought have all had their accessories.
Its best to count on getting nothing but a bare board, this way, anything that's included will be a welcome surprise.:)
I've only bought two open box mobos from the egg (if the savings isn't over $25 I wouldn't bother) and they both had all of the accessories *except* for the IOShield... which is really the only accessory I care about other than the SLI/Crossfire bridge
I bought a few from egg and mostly bare board in brown box without accessories. It's a hit-or-miss.
i just got one in on monday, mb, back plate, 2 sata cables and an ide cable. as long as i get the mb and back plate im happy.
I have plenty of faith in human stupidity, just not much in my own luck. I'm the guy that gets pulled over, without fail, on the way to the auto parts store to replace a burnt out tail light.
I bought 3 open box mobos so far and all 3 came with full accessories, however all 3 came with issues or DOA, so i am pretty much never buying open box from newegg again.
Open box is a mixed bag. I got most boards open box just a bare board. Got one Asus board that the onboard sound didn't work, bottom PCI slot didn't work and the top PCI slot only worked sometimes if there was a video card plugged in.
my crosshair IV formulacame with I/O shield, some cables, and a plain white box. i guess i was somewhat lucky.
ive done 2 Open Box boards and Received one in good standing & the other one was Missing everything even the cmos battery and jumpers on the board, missing all sata cables n all.
its a chance you take with open box.
Not quite the same topic, but has anybody ever received a "new" motherboard from newegg but had a suspicion that it was used? I got a motherboard the other day (Gigabyte) that was missing the easy plug attachment for hooking the power/reset/hd/speaker wires up easy. Then the motherboard failed during the Windows install, rebooting right when finalizing a windows 7 install.
got a open box today and it looked like i bought a new one.. newegg is great.
As long as you buy with the expectation that you'll get nothing but a plain motherboard, their open box deals are great. If you get a box or accessories, consider it a bonus :)
I've bought several open-box mobos from newegg. Like everyone else said, expect to get nothing but a board in an anti'static bag and sometimes you'll be pleasantly suprised.
