Stolen from another forum.
https://www.newegg.com/msi-radeon-r...als-_-P0_14-137-690-_-10262022&quicklink=true
Enjoy!
Enjoy!
Not severely, but if you want to guarantee 60+ fps in modern titles then you'll need to step up a tier.Is this severely hampered by the 128-bit memory interface at 1440p?
Considerably faster than the 3050 but roughly in the same neighborhood as a 3060 probably a smidge lower as long as you don't do anything specific to the card e.g. DLSS or ray tracing, if you do use DLSS though then the 3060 smokes it.Between which Nvidia cards does the 6600 fall between?
If your have B550/x570 for PCI Express 4 it's faster then Express 3 as I tested that myself, my Sapphire Pulse RX 6600 in locked at 100watt/ use the power slide to + 10 or +20 and then that allows the RX6600 to use 110 watts or 120watts, this will speed the card up more and you have to by pass the bios limit to use the full board power of the design on my card, but it should run as fast as the XT if can give the juice it needs.Thanks for posting this! Picked it up for my soon to be 16 year old for his bday coming up or Xmas. Should be a nice upgrade from his GTX 1650 low profile card I got him almost 3 years ago. He has a 1080p 144hz monitor and 5600x so should work well with that.
