Newegg having issues with Thermalright?
MrFace
Finally decided to buy a CPU cooler and see Newegg has ZERO thermalright heat sinks in stock :(
I'm just going to get a Tuniq Tower 120 with the blue LED fan instead :)
Thanks guys.
Directron
SVC
Coolerguys
Heatsinkfactory
Performance-PCs
Jab-Tech
FrozenCPU
etc
NewEgg is not the only online retailer selling HSFs. ;)
IME Directron has had the cheapest prices on the TRUE anyway. Bought both of mine for $49 whereas most sites are $55-$60+.
Appreciate it guys! My main concern is getting my stuff here by Friday. I live close to Memphis so I tend to get Newegg stuff within 1-2 days :)
Directron
SVC
Coolerguys
Heatsinkfactory
Performance-PCs
Jab-Tech
FrozenCPU
etc
Good List. Very fond of svc myself. Been using them for years.
While newegg is the best average they are not always the end all be all. Its nice to have choices. Even if 80% of our stuff we get at newegg :D
Anyone have any idea if I'd be able to use the Tuniq Tower 120 w/fan and ALSO the Corsair memory cooler?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835704001
(Assuming your board is still the IP35 Pro in your sig) Yes it should work fine.
I'm using the Dominator fan module along with the TRUE and I have an S-Flex SFF21E mounted on the side closest to the fan module and it all still fits ok with an inch or so to spare. I've actually used that setup on both my IP35 Pro and the IP35-E and not had any clearance issues. :)
