- Jan 26, 2007
i was looking at newegg just a little bit ago and saw they added a AM3 socket
here is the link http://www.newegg.com/Product/Product.aspx?Item=N82E16813153129
JetWay JHA04-LF AM3 AMD 790FX ATX AMD Motherboard - Retail
Brand JetWay
Model JHA04-LF
Supported CPU
CPU Socket Type AM3
CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
FSB 2600MHz Hyper Transport (5200 MT/s)
Chipsets
North Bridge AMD 790FX
South Bridge AMD SB600
Memory
Number of Memory Slots 4×240pin
Memory Standard DDR2 1066
Maximum Memory Supported 8GB
Channel Supported Dual Channel
Expansion Slots
PCI Express x16 1 x PCI Express x16@16-lane and 2 x PCI Express x16@8-lane (For ATI Cross Fire X Technology, x16 + x16 or x8 +x8 +x16; When install the "Switch Card" into PE-3, the PE4 will offer 16-lane)
PCI Slots 2
Storage Devices
PATA 1 x ATA100 2 Dev. Max
SATA 3Gb/s 4
Onboard Video
Onboard Video Chipset None
Onboard Audio
Audio Chipset Realtek ALC888
Audio Channels 8 Channels
Onboard LAN
LAN Chipset Marvell 88E8056
Max LAN Speed 10/100/1000Mbps
Rear Panel Ports
PS/2 2
USB 6 x USB 2.0
eSATA 1 x eSATA 3Gb/s
S/PDIF Out 1x Coaxial
S/PDIF In 1x Coaxial
Audio Ports 6 Ports
Onboard USB
Onboard USB 2 x USB 2.0/1.1 headers for 4 USB 2.0/1.1 ports
Physical Spec
Form Factor ATX
Power Pin 24 Pin
still not am3 socket phenom II's -.-
Brand JetWay
Model JHA04-LF
Supported CPU
CPU Socket Type AM3
Chipsets
Memory
Expansion Slots
PCI Slots 2
Storage Devices
SATA 3Gb/s 4
Onboard Video
Onboard Audio
Onboard LAN
Rear Panel Ports
PS/2 2
USB 6 x USB 2.0
Audio Ports 6 Ports
Onboard USB
Physical Spec
Form Factor ATX
Power Pin 24 Pin
