Newegg Fans 20% off
I am tempted to get a 120 enermax vegas duo for the front as I have one 140mm as the exhaust fan but I think they are too bright...but look darn cool :D
Hmm $10.31 for the Xigmateks or $11.17 for the Cool masters and then having to deal with the hassle of a $5 gift card.
are the Xigmateks any good? I see a decent high Static pressure. Are they really 75 CFM?
They aren't 75 CFM, Newegg has the wrong specs listed. These are around 45 CFM and are silent. (I purchased a pack the other day)
Will either of those work with PWM? How loud are they? They claim 20 and 19 dba, though I am wondering how loud they actually sound as the measurements are often off.
Would not mind getting some better airflow than my two old Antec tri cools (at lowest setting) with similar low noise.
And will the Xigmateks work well with a Xigmatek 120mm Gaia?
They use the same model number but different product number for two different fans. The 4 pack are these.
Neither the Xigmatek or Cooler Master are PWM, though chances are if your motherboard doesn't support fan profiling on the CPU headers (ASUS) it still supports it on the case fan headers.
I don't recommend either for use on a radiator but for case airflow they're both good.
Dang, really wanted a second 140mm NZXT white blade fan, but the code doesn't seem to work for it. Need a second one for my Source 210 Elite case.
Went with two Cougar 140mm fans for less than $20. They be orange too, gonna have a Halloween themed server. lol
I put them on my radiators and they cool better at 900rpm than the stock fans at 1900rpm. Can't hear them at that speed.
If you want to deal with a rebate for a fan, you can get the Excaliber 120mm, reg $18 for $4.40, Megaflow 200mm for $5.60, Or Cooler Master R4-S4S-10AK-GP 16dB 140mm for $4.60.
The Excalibers look like good radiators fans, 86 cfm and 3.5mm/water, but one rebate per household isn't useful if you want to do push/pull.
I've got two on my H50 cooling my 7870 MYST and it never goes above 42c while gaming. :D
that coolermaster excalibur looks like its extremely [H]ot at that price..... especially for a pwm fan.....
