NewEgg $29 Refurb Mobos again
theHeat
They just updated not too long ago. Check it out, they have a few, but no ABit this time. I went ahead and ordered a GIGABYTE GA-7VT600 1394, not such a bad deal for $30 shipped :D
Happy shopping.
quite a few boards there for intel and AMD. Nothing there that I needed tho. Good post.
Just got the MSI KT8 NEO FSR2 for 45 dollars... This seems like a good deal, I dunno, I have heard mixed reviews on this board. What do you guys think?
older K8T800 chipset, no pci/agp lock, doesnt like anything over 800HTT, poor overclocker. I wouldnt touch it personally. Chaintech ZNF-250 for under $90 would new would be a much better long term choice.
I'm glad I could help some of you out :D
I was just getting ready to go to bed @ 1 and I decided to look. Man, you should have seen me. Opening like 10 windows, getting reviews on 4 different motherboards, adding them all to my cart so they wouldn't sell out. I was so paranoid, haha.
I hope mine comes just as retail would :)
CAREFULL I've bought many refurbished boards from NewEgg, and I have to say I have had very good luck with them, but they usually do not come with accessories, like USB brackets, drivers (not a big deal if you can download and burn them,) and back plates (the ATX plate to make the back connectors fit in a case.) If you're cool with a bunch of open space in the back of your case where they connectors are, go for it, they're great deals, but remember what could be missing.
My current MSI 865GM2-LS was a refurb, and it worked great, and had most of the cables, but no back plates. Same with some AS-Rock boards I bought as backups for customer machines (I've been using the AS-Rock boards for some time and wanted some spares on hand) and none of them had back plates, I could order them for $6 though through AS-Rock though.
Well, good job [H] shoppers, they're pretty much out of stock on the good ones now :p
I plan on using this mobo in a custom fabbed case though, so no worries on the backplate.
I know they dont come with accessories. I have all the cables I need already, and the back plate and cpu HSf bracket i can buy with the new heatsink. thanks for the heads up though.
the MSI K8T NEO FSI2R that i got for 46 is a great deal even though no accessories. the board is still selling for 113 new!!!
Thanks for the heads up on the accessories. I may pick one of these up to use in a file server.
They can still be bought even when in your cart. Its only in the very last ordering stage that it becomes reserved, and if you exit that window to continue shopping, it becomes unreserved again...i've had many a good refurb deal taken out from under me in the exact same fashion.
Yeah, I know, that's why I did it. Some companies, if you order it and they process it, but don't have it in stock, offer you the next available one or one of equal or greater value. NewEgg doesn't do that though. Wishful thinking on my part :p
Um, these refurbs have been up since AT LEAST Tuesday. I was looking for something on Tuesday and these were the same mobos that were up then.
The current ones, yes. The deal is over and the ones that WERE up are not anymore.
I purchased one of the MN31N boards from an earlier hot deal - it came defective (Bad IGP, though it had a pretty good selection of accessories). I can't say how good Newegg would be about replacing it - as I couldn't test it till after the 15 day warranty expired.
Ive bought a lot of newegg refurbs. All Abit boards I ordered came full retail (ordered 5 diff. boards total). One of my boards, BE7, had a bad BIOS chip. My bro ordered some Asus board, it was DOA and OEM. I ordered a vid card and the came DOA. And lastly ordered a Liteon burner, it came with everything other than the blank media. I would go ahead and order because if it is DOA they will exchange it. And their RMA service is quick.
Damn, that sucks for you. I've ordered 5 refurb mobos from newegg and they all work great. Atleast they RMA is quick.
just email tech support and tell them you just got around to testing it after the 15 day perios expires they will (they did for me and it was a good 15 days past) send you an rma number newegg is cool like that.
