NEWARK FTWI(illa Bee said:I say go Venice...
Dude, my Sempron 2800+ was just as good in Windows as my Opteron 146, even 400mhz faster, it still feels the same, unless you benchmark a lot, you shouldn't notice that little difference, it's not a Celeron afterall.I(illa Bee said:Sempron? comparable to a newcastle or clawhammer..?
The lack of Cache on the semprons make them slugish in windows, there are very cases I would even think about a sempron..
takes abuse in a stride.. 90nm doesn't as muchWhoBeDaPlaya said:You prefer 130nm? If it's the ClawHammer, I understand, but probably not the Newcastle right? Palermos whup them something bad![]()
Example: Core Lapping(cf)Eclipse said:takes abuse in a stride.. 90nm doesn't as much![]()
i've yet to see a clawhammer do 3.1ghz on airnoobtech said:the highest overclocks were done on the clawhammers... but Old and over priced these days.
Wow.. 0.90nm! That's incredibly small! Where do I find this?noobtech said:Venice is better cause it is .90nm and runs on lower voltage, can over clock higher, has newer instructions like SSE3... and it's cheap. I say go with this one for the win!!!
I thought the Venice generally goes higher? eg. my CH 3700+ can't really push past 2.7GHz (stock is 2.4GHz).noobtech said:the highest overclocks were done on the clawhammers... but Old and over priced these days.
i have a friend who can get 4000+'s for around $300, i'm sure the lower models are equally cheap. the 3400+.. if you can find one, why not?mathot said:Eclipse, where are the best prices on Newarks? Shentech is outta stock on the 3700, but they have the 3400 for $180. Whats your take on a 3400 Newark?
