NEWBIE watercooling question
Episode666
the Koolance Exos 2:
Being a newbie to watercooling, I want to watercool my new system (in a Lian-Li v1000) and an all-in-one system like the Exos looks like just what I need.
I'm a little unclear about how to install one of these though. Do you have to drill any holes into the top of the case? If not, where do the pipes go? I don't think I'm prepared to cut into my $230 case...
Regarding that Petra page, I'm not sure which one would really be right for me. I'm buildinng AMD / 939 / SLI system (But I'm starting off with one video card for now)
Are these kits pretty self-explanatory? Pump goes to CPU, CPU goes to GPU, GPU goes to Pump? or is there more to it?
Or, you could purchase a KOOLANCE case that has the Exos built into.
http://www.xoxide.com/koolance3.html
I would have mentioned the Koolance Aquian ICM-505 Internal Cooling System which is an all in one unit, but you said that you are using a Lian-Li V series case, and due to it's non-standard ATX layout the kit wont mount properly.
you can get a bracket for the back of your pc with 2 holes in it for your pipes. not sure wat site but am sure it'll be easy 2 find with a search round google. real handy
