Hi folks,
I'm completely new to installing water cooling, although I've been building PCs for about a decade. I've had a read through the FAQs here as well.
I'm just after tips in terms of what would be a good system to start with, and/or what systems/makes should be avoided. My primary aim is to get a quieter system (implicit with water cooling it seems), with the secondary aim of a cooler system.
I want to cool the CPU (Athlon XP) and the Northbridge/nForce chipset, which is surprisingly hot (using an Asus A8N-E motherboard). I'm not worried about the graphics card so much, an ATI Radeon X850 Pro.
The whole lot is currently mounted in a Coolermaster Centurion Case, and just to note I have 5 hard disks (a mixture of IDE and SATA).
I've seen mention of gravity fed systems, that presumably work off convection. I think someone has said Coolermaster have one, and I think I spotted one at Overclockers.co.uk. Are these worthwhile? I like the idea.
Any advice appreciated.
Thanks
Thanks
