Newbie rebuild ?'s
loswho
I've narrowed my motherboard and processor down to ASUS M2N-E nForce sli mcp atx AMD and the processor to AMD athlon 64 X2 5200 windsor 2.6ghz am2 and 2gb of ram.
I play mostly online and surfing the internet, Is this too much or not enough? any other suggestions.
How much are you wanting to spend ?
What video card are getting?
Is there a reason you don't wanna E6300?
2gb of memory is good idea.
I already have Geforce 7600Gt. I Would like to stay around 350$ tops for motherboard and processor. I would like to stay with amd, but is the e6300 better?
The E6300 is a good processor but isn't going to outpace the 5200 by any margin. The E6400 would probably be a better choice. That competes pretty well with that processor and for the same price.
SoulMan901
Yes the core 2 duo e6300 is probibly about the same but much cheaper, you should get a e6400 or higher then It would be better then your x2 cpu.
Remember this, Core 2 Duo, the world's best processor :D
I have a amd 3200+ in my comp which I built 1-2 years ago. Otherwise If I was building my computer now, I would go with C2D
good luck.
Loswho,
hey man, from what i have priced at www.newegg.com with the setup you are looking at, you are close to breaking over your $350 limit. so lets see what i can come up with for you as a intel setup, as posted lets go with the cpu msg1285 sugested. ill post links for the best bang for the buck parts from newegg and you can go off of that. hope this helps
Intel Core 2 Duo E6300 CPU
http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
Intel BOXDP965LTCK LGA 775 Intel P965Express ATX Intel Mobo
http://www.newegg.com/Product/Product.asp?Item=N82E16813121035
you will have to buy new memory for this setup here is the cheapest but best for the bang for the buck memory setup to get you running. ill put 1gb setup to get you up and going and a 2gb setup to make it worth getting along with the mobo and cpu setup.
Patriot 1GB 240-Pin DDR2 800 (PC2 6400) Memory
http://www.newegg.com/Product/Product.asp?Item=N82E16820220088
Patriot eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 800 (PC2 6400) Dual Channel Kit Memory
http://www.newegg.com/Product/Product.asp?Item=N82E16820220144
you could probably buy two of the 1gb sticks and probably come out alittle cheaper, but that 2gb kit is well worth it for the price. hope this helps.
I don't know if you're interested in overclocking or not, but if you are the Intel board won't do. You'd have to look at something like this...
Biostar
http://www.newegg.com/Product/Product.asp?Item=N82E16813138037
Gigabyte
http://www.newegg.com/Product/Product.asp?Item=N82E16813128017
If you're not going to overclock, some memory like this would be fine...
Corsair
http://www.newegg.com/Product/Produ...temList=N82E16820145167%2CN82E16820145015
OCZ
http://www.newegg.com/Product/Product.asp?Item=N82E16820227118
This GSkill also deserves a look. It is DDR2-800 like the modules listed below, just with 5-5-5-15 timings. For the price, it looks pretty good, as it costs about the same as the modules listed above which are rated slower than DDR2-800, but have tighter timings.
http://www.newegg.com/Product/Product.asp?Item=N82E16820231098
If you are going to overclock, the 2GB Patriot listed above is a nice choice, you can also check out these Corsair modules....
http://www.newegg.com/Product/Produ...mpareItemList=N82E16820145590,N82E16820145034
I think you all may have changed my mind, Hows this combo sound: Intel BOXDP965LTCK LGA 775 Intel P965Express ATX Intel Mobo and either a E6300 or 6400 havent made up my mind on that yet.
loswho, hey man, glad that we all can be a help with a fellow Hard Forum Member in need of some upgrade questions.
if you are not into overclocking then the intel mobo will be fine, you are just buying features that you may never use on the other mobo's that got posted. sorry, but if you just want a mobo that does the basics to play games and surf the web, then this board is perfect.
as far as your pick goes, its a good choice. to get you started in the core 2 duo world, i would start with the E6300. from what im reading peeps are getting them clocked up pretty high and some are running them at stock settings and mowing through the high end games like a breeze on stock settings. if you are not going to overclock then the Intel Mobo and Intel E6300 cpu will work fine, just make sure that your power supply has the newer mobo power connectors.
you will need the new 8-pin CPU power connector and 24-pin ATX power connector. if it doesnt have the 8-pin connector and you have the 4-pin instead. in the motherboard box they will have a converter to make your 4-pin to a 8-pin connector. but make sure you have the 24-pin as it is really best to run with the newer 24-pin connectors, as there might be some power that your other psu could not supply to the newer mobo.
I have a year old 350w power supply but I am going to get a 500w. I have one last question for you guys. I didn't put the processor in my last mobo, how hard is it to do? any special helpful ideas? Thanks fellows.
it's really easy. just follow the instructions that come with the CPU.
