Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I found a frayed wire on the IDE strap to my HDD could this short out a MOBO?
Power is flowing through the mobo to the mouse but can't get CPU to start
did it ever work or is this a new build? (one thing that came to mind is that your CMOS reset jumper may be in the wrong position or the switch on the back of your power supply may be off OR since you are a newbie, your comptuer may not be plugged in)
ah, the old demon harddrive issue. well, try the mobo with a different power supply and/or the power supply with a different mobo. Also, make sure your CPU is seated fully.
The story goes ... like this
Helping a buddy out with his. ( MOBO got fried maybe same issue as mine now)
Testing out on mine ... working sporadically... was checking as to why it was missbehaving now mine don't work either.
Power supply was okay I have tried 4 different ones that are/were all reliable.
CPU seated like a j lo's ass in a tight pair of jeans.
Fans are not spinning up ... Feels like the power switch signal is not making it throught the MOBO to the start the power supply, but I know the switch is good I have 2 that were working just fine the day my MOBO would not start and I have tested with both.
If you tried to post without any HDD's, floppies, CD-ROMs, or any extra PCI cards that you don't need, and you know the powersupply is good, I don't know what else it could be. Possibly the CPU. Do you have access to a mobo that is compatible? (That is an older machine)
So, did you put his powersupply in your machine and now yours doesn't work? Because if that's the case I wouldn't stick that powersupply in any other computers.
