I got a used Logitech TV CAM HD that is great but unfortunately is unusable right now due to MicroSoft/Skype non-updates.
Basically the webcam won't start until it tests the internet connection by pinging www.skype.com. Its a huge problem skype users are facing with built in Skype TV Hardware.
Anyways one of the solutions is this:
Solution: If you have a router / firewall / own administered DNS Server, create an entry www.skype.com and direct it to an other IP-Address which you can ping (e.g. your own default gateway)
I own a Nighthawk R7000 and can port forward etc. but not sure how to redirect a url...
Any help would be very appreciated, thank you.
