Wordsmith9091
- Dec 9, 2005
I'm generally technically literate but haven't had a reason to think about memory and how it relates to FSB since I overclocked an old K62-400, so I'm a little behind on all this. I read the FAQ, and it helped a little, but I'm still kinda confused ...
I have this chip in my machine: http://www.compusa.com/products/product_info.asp?product_code=307314&pfp=BROWSE
The manufacturer apparently used ddr333 for the 512mb stick that's in there. Is this really the best match? I read about not wanting to use an async mode on AMD chips -- is that what I'm doing with the current setup? I'm planning on buying more memory soon, and I want to know if I should add on to the current dimm, or, if it's not the best speed for this machine, just replace it entirely.
Thanks for any help you guys can give.
