kenshinjeff
- Apr 17, 2012
Hi guys,
I'm new to using RAID, expander cards, and enclosures, I was hoping that someone might be able to help me build a system for my home.
I have a bunch of hardware and disks lying around, different manufacturers different sizes. After some digging, here's what I roughly came up with.
- LSI MegaRaid 9260-4i
Internal Port 1x SFF-8088
- ChenBro SAS Expander Card CK12803
Internal Port 1x SFF-8087 (TO RAID CARD), 4x SFF-8087 (TO BACKPLANE)
External Port 1x SFF-8088 (IN?), 1x SFF-8088 (OUT?)
- Norco RPC-4220
4U, 20 hotswap, etc. etc.
1) I understand both RAID/SAS expander cards can accept SAS/SATA3/SATA2 harddisks, but can it support a configuration like this simultaneously?
- RAID 10 for 4 SAS harddisks with 1 hotspare on standby
- RAID 5 for the remaining 6 SATA2 and SATA3 harddisks
2) Assuming that I have set this already setup, how do I add more harddisks after I run out of space? Is it as "simple" as buying new harddisks of the same size, putting them into the enclosure, reboot the system and go back to the RAID management screen in the bios?
3) Is it possible to mix and match the SATA2/3 harddisks of different sizes into the RAID5 configuration? Is there a better configuration to be able to add more cheap harddisks as and when I require?
From the 9260-4i specsheet, it says the data transfer rates is up to 6Gbps per port. How do I calculate the theoratical max data rates?
4A) 9260-4i to fanout cable to 4 SAS 6Gbps drives:
= 4 drives x 6 Gbps ?
4B) 9260-4i to 3Gbps SAS Expander to 4 fanout cables to 4 SATA3 6Gbps drives:
= 16 drives x 3 Gbps?
4C) 9260-8i dual linked to 3Gbgps SAS Expander to 4 fanout cables to 4 SATA3 6Gbps drives:
= 16 drives x 3 Gbps x 2 links?
5) From the wiki, I gather PCI-E v2 is 8GB/s, which is 64Gbps. How possible is it to reach this limitation? When I have reached this limitation, is the cheapest method to expand this configuration?
6) Incidentally, I realise the chenbro sas expander card has 2 external ports, one is in and the other is out. How do these work?
Thanks in advanced for any answers that anyone can provide!
- Norco RPC-4220
