Chaintech 7NJS Ultra Zenith
Barton 2800+
BBA X800 XT PE
2X512mb K-Byte PC3200 Dual Channel
WD 120gig 7200RPM
SB Live 24bit.
Windows XP SP2
I know this thing can go faster then stock speeds.
MY Barton 2800 is unlocked I can change the Multi.
Don't know much about my ram, any suggest on timing and stuff like that??
Problems are this
For some reason at stock speeds I have to put my vcore to 1.7 for stability, I think my board under volts or something.
I need to know optimal settings for this rig. Information that you need that I have left out just ask.
My HSF is THIS
Come on help me out i know this barton can go higher.
I got my GFs sempron 2800+ s754 from 1.6 to 2.4, I know my barton should overclock better.
LMK what to do.
Barton 2800+
BBA X800 XT PE
WD 120gig 7200RPM
SB Live 24bit.
Windows XP SP2
Problems are this
My HSF is THIS
LMK what to do.
