rpeters83
- Jan 11, 2009
I've never overclocked before but wanted to try it out for curiosity sakes. I've read the basics but not sure how far I can go with my specific setup.
I have a mini ITX board, a silverstone 80mm low profile cooler covering an AMD athlon 4850e. chipset is nvidia 8200 and ram is PC26400 ddr2.
I'm able to adjust the FSB and the voltage in the bios but not sure how high I can go. I have the voltage set to auto and the FSB is up to 215 from the stock 200, making my cpu a little less than 2.7 up from 2.5.
How high can I do with my setup? What do I need to do with the voltage if i want to go higher? Is prime95 a good way to sort of stress test? I use the system for watching movies as well as some light gaming on the TV. Thanks.
Ryan
Ryan
