Newbie needs some advice
When I run folding@home-gpu, I get the error "At present your GPU is not supported or you need a current driver." What is the fix for this?
FYI. ATI 5xxx series gpus require the -forcegpu ati_r700 switch to run properly.
Per Dookey.
I think all you have to do is copy this flag into the config menu of the GPU client if it gets that far. Otherwise I think you need to create a shortcut to start the client. right click on the shortcut and go to properties. Add that flag onto the end of the contents of the target box. Be sure to include a space between the end of the filename and the dash.
@ Kendrak, He has a ATI 5850, No cuda, sir.
Per Dookey.
To add this flag, go into the configuration window for the client, click on the Advanced tab, and put it in the box at the bottom titled "Additional Client Parameters".
Ya, I just wasn't sure by his post if the client was even starting.
So I put that in my Start in box in properties and it now reads:
C:\Users\Sean\AppData\Roaming\Folding@home-gpu\ -forcegpu ati_r700
But I'm still getting the same error. Did I do something wrong?
Yes, you did something wrong. The flag should be included in the Target box, not the Start box. The Target line should look like this:
C:\Users\*******\AppData\Roaming\Folding@home-gpu\Folding@home.exe -forcegpu ati_r700
Not to go off subject, i messaged you about the processor AARP.
Kendrak currently has 1st dibs on it, but I won't be posting it until at least the weekend. If something changes between then and now you'll have dibs.
Hmm, it seems I don't have a target line.
Get rid of the startup shortcut that the install gives you. Create a shortcut directly from the .exe in the folding@home directory. Then you put the flag I gave you earlier in the thread in the target box.
You will also need to give the shortcut created admin rights.
Muchas Gracias.
Ok, Everything is working perfectly. Under the advanced tab should I check "Do NOT lock cores to specific CPU"? Also, is there a way to view my combined PPD with both the processor and GPU?
Yep, I recommend you check the box you mentioned. FAHMON is a great program to see your PPD. Google the download and then add the gpu client directory and then the VM directory. Be sure to check the box for the VM directory that it is running a virtual client.
There's a sticky above that tells you how to setup FAHMON. Come back here if you need help.
Directory for VM is \\fold-xxxx\C\etc\folding\1\
xxxx=what the VM selects. You will see it in the window.
Aha. Yep, I already have FAHMON for my CPU but didn't know that I could add my GPU. What would the path look like?
I'm running windows 7 64 bit and my path is:
c:\program files (x86)\folding@home\folding@home-gpu\
K, I think everything is set up correctly now. What should my PPD be averaging?
I didn't notice if you posted cpu ghz, but I'm thinking you should be getting at least 6-7k between the cpu and gpu.
A NV gpu would be faster. My 5870 at stock gets about 4.2k and my cpu gets around 4.5k.
Since I'm running xfire I can't use my second 5870.
Hmm. Something isn't working. I'm only getting a dismal 756.00* PPD on my CPU and 1435 PPD on my GPU. I looked at my vm and I see this message "# hrtimer: interrupt too slow, forcing clock min delta to 8619969 ns" Could that be why my CPU PPD is so low? Also, in taskmanager my CPU is running at full usage. What could be my problem?
Are the clients set to 100% usage? Is the VM notfred? And maybe the GPU isn't clocking up to 3D clocks...?
post log file please
--- Opening Log file [November 20 23:22:20]
# SMP Client ##################################################################
Folding@Home Client Version 6.02
http://folding.stanford.edu
Launch directory: /etc/folding/1
Executable: ./fah6
Arguments: -local -forceasm -smp 8
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[23:22:20] - Ask before connecting: No
[23:22:20] - User name: AARP (Team 33)
[23:22:20] - User ID: 60A8B9308C203AA
[23:22:20] - Machine ID: 1
[23:22:20]
[23:22:21] Loaded queue successfully.
[23:22:21]
[23:22:21] + Processing work unit
[23:22:21] Core required: FahCore_a2.exe
[23:22:21] Core not found.
[23:22:21] - Core is not present or corrupted.
[23:22:21] - Attempting to download new core...
[23:22:21] + Downloading new core: FahCore_a2.exe
[23:22:21] + 10240 bytes downloaded
[23:22:21] + 20480 bytes downloaded
[23:22:21] + 30720 bytes downloaded
[23:22:21] + 40960 bytes downloaded
[23:22:21] + 51200 bytes downloaded
[23:22:21] + 61440 bytes downloaded
[23:22:21] + 71680 bytes downloaded
[23:22:21] + 81920 bytes downloaded
[23:22:21] + 92160 bytes downloaded
[23:22:21] + 102400 bytes downloaded
[23:22:21] + 112640 bytes downloaded
[23:22:21] + 122880 bytes downloaded
[23:22:21] + 133120 bytes downloaded
[23:22:21] + 143360 bytes downloaded
[23:22:21] + 153600 bytes downloaded
[23:22:21] + 163840 bytes downloaded
[23:22:21] + 174080 bytes downloaded
[23:22:21] + 184320 bytes downloaded
[23:22:21] + 194560 bytes downloaded
[23:22:21] + 204800 bytes downloaded
[23:22:21] + 215040 bytes downloaded
[23:22:21] + 225280 bytes downloaded
[23:22:21] + 235520 bytes downloaded
[23:22:21] + 245760 bytes downloaded
[23:22:21] + 256000 bytes downloaded
[23:22:21] + 266240 bytes downloaded
[23:22:21] + 276480 bytes downloaded
[23:22:21] + 286720 bytes downloaded
[23:22:21] + 296960 bytes downloaded
[23:22:21] + 307200 bytes downloaded
[23:22:21] + 317440 bytes downloaded
[23:22:21] + 327680 bytes downloaded
[23:22:21] + 337920 bytes downloaded
[23:22:21] + 348160 bytes downloaded
[23:22:21] + 358400 bytes downloaded
[23:22:21] + 368640 bytes downloaded
[23:22:21] + 378880 bytes downloaded
[23:22:21] + 389120 bytes downloaded
[23:22:21] + 399360 bytes downloaded
[23:22:21] + 409600 bytes downloaded
[23:22:21] + 419840 bytes downloaded
[23:22:21] + 430080 bytes downloaded
[23:22:21] + 440320 bytes downloaded
[23:22:21] + 450560 bytes downloaded
[23:22:21] + 460800 bytes downloaded
[23:22:21] + 471040 bytes downloaded
[23:22:21] + 481280 bytes downloaded
[23:22:21] + 491520 bytes downloaded
[23:22:21] + 501760 bytes downloaded
[23:22:21] + 512000 bytes downloaded
[23:22:22] + 522240 bytes downloaded
[23:22:22] + 532480 bytes downloaded
[23:22:22] + 542720 bytes downloaded
[23:22:22] + 552960 bytes downloaded
[23:22:22] + 563200 bytes downloaded
[23:22:22] + 573440 bytes downloaded
[23:22:22] + 583680 bytes downloaded
[23:22:22] + 593920 bytes downloaded
[23:22:22] + 604160 bytes downloaded
[23:22:22] + 614400 bytes downloaded
[23:22:22] + 624640 bytes downloaded
[23:22:22] + 634880 bytes downloaded
[23:22:22] + 645120 bytes downloaded
[23:22:22] + 655360 bytes downloaded
[23:22:22] + 665600 bytes downloaded
[23:22:22] + 675840 bytes downloaded
[23:22:22] + 686080 bytes downloaded
[23:22:22] + 696320 bytes downloaded
[23:22:22] + 706560 bytes downloaded
[23:22:22] + 716800 bytes downloaded
[23:22:22] + 727040 bytes downloaded
[23:22:22] + 737280 bytes downloaded
[23:22:22] + 747520 bytes downloaded
[23:22:22] + 757760 bytes downloaded
[23:22:22] + 768000 bytes downloaded
[23:22:22] + 778240 bytes downloaded
[23:22:22] + 788480 bytes downloaded
[23:22:22] + 798720 bytes downloaded
[23:22:22] + 808960 bytes downloaded
[23:22:22] + 819200 bytes downloaded
[23:22:22] + 829440 bytes downloaded
[23:22:22] + 839680 bytes downloaded
[23:22:22] + 849920 bytes downloaded
[23:22:22] + 860160 bytes downloaded
[23:22:22] + 870400 bytes downloaded
[23:22:22] + 880640 bytes downloaded
[23:22:22] + 890880 bytes downloaded
[23:22:22] + 901120 bytes downloaded
[23:22:22] + 911360 bytes downloaded
[23:22:22] + 921600 bytes downloaded
[23:22:22] + 931840 bytes downloaded
[23:22:22] + 942080 bytes downloaded
[23:22:22] + 952320 bytes downloaded
[23:22:22] + 962560 bytes downloaded
[23:22:22] + 972800 bytes downloaded
[23:22:22] + 983040 bytes downloaded
[23:22:22] + 993280 bytes downloaded
[23:22:22] + 1003520 bytes downloaded
[23:22:22] + 1013760 bytes downloaded
[23:22:22] + 1024000 bytes downloaded
[23:22:22] + 1034240 bytes downloaded
[23:22:22] + 1044480 bytes downloaded
[23:22:22] + 1054720 bytes downloaded
[23:22:22] + 1064960 bytes downloaded
[23:22:22] + 1075200 bytes downloaded
[23:22:22] + 1085440 bytes downloaded
[23:22:22] + 1095680 bytes downloaded
[23:22:22] + 1105920 bytes downloaded
[23:22:22] + 1116160 bytes downloaded
[23:22:22] + 1126400 bytes downloaded
[23:22:22] + 1136640 bytes downloaded
[23:22:22] + 1146880 bytes downloaded
[23:22:22] + 1157120 bytes downloaded
[23:22:22] + 1167360 bytes downloaded
[23:22:22] + 1177600 bytes downloaded
[23:22:22] + 1187840 bytes downloaded
[23:22:22] + 1198080 bytes downloaded
[23:22:22] + 1208320 bytes downloaded
[23:22:22] + 1218560 bytes downloaded
[23:22:22] + 1228800 bytes downloaded
[23:22:22] + 1239040 bytes downloaded
[23:22:22] + 1249280 bytes downloaded
[23:22:22] + 1259520 bytes downloaded
[23:22:22] + 1269760 bytes downloaded
[23:22:22] + 1280000 bytes downloaded
[23:22:22] + 1290240 bytes downloaded
[23:22:22] + 1300480 bytes downloaded
[23:22:22] + 1310720 bytes downloaded
[23:22:22] + 1320960 bytes downloaded
[23:22:22] + 1331200 bytes downloaded
[23:22:22] + 1341440 bytes downloaded
[23:22:22] + 1351680 bytes downloaded
[23:22:22] + 1361920 bytes downloaded
[23:22:22] + 1372160 bytes downloaded
[23:22:22] + 1382400 bytes downloaded
[23:22:22] + 1392640 bytes downloaded
[23:22:22] + 1402880 bytes downloaded
[23:22:22] + 1413120 bytes downloaded
[23:22:22] + 1423360 bytes downloaded
[23:22:22] + 1433600 bytes downloaded
[23:22:22] + 1443840 bytes downloaded
[23:22:22] + 1454080 bytes downloaded
[23:22:22] + 1464320 bytes downloaded
[23:22:22] + 1474560 bytes downloaded
[23:22:22] + 1484800 bytes downloaded
[23:22:22] + 1495040 bytes downloaded
[23:22:22] + 1505280 bytes downloaded
[23:22:22] + 1515520 bytes downloaded
[23:22:22] + 1525760 bytes downloaded
[23:22:22] + 1536000 bytes downloaded
[23:22:22] + 1546240 bytes downloaded
[23:22:23] + 1556480 bytes downloaded
[23:22:23] + 1566720 bytes downloaded
[23:22:23] + 1576960 bytes downloaded
[23:22:23] + 1587200 bytes downloaded
[23:22:23] + 1597440 bytes downloaded
[23:22:23] + 1607680 bytes downloaded
[23:22:23] + 1617920 bytes downloaded
[23:22:23] + 1628160 bytes downloaded
[23:22:23] + 1638400 bytes downloaded
[23:22:23] + 1648640 bytes downloaded
[23:22:23] + 1658880 bytes downloaded
[23:22:23] + 1669120 bytes downloaded
[23:22:23] + 1679360 bytes downloaded
[23:22:23] + 1689600 bytes downloaded
[23:22:23] + 1699840 bytes downloaded
[23:22:23] + 1710080 bytes downloaded
[23:22:23] + 1720320 bytes downloaded
[23:22:23] + 1730560 bytes downloaded
[23:22:23] + 1740800 bytes downloaded
[23:22:23] + 1751040 bytes downloaded
[23:22:23] + 1761280 bytes downloaded
[23:22:23] + 1771520 bytes downloaded
[23:22:23] + 1781760 bytes downloaded
[23:22:23] + 1792000 bytes downloaded
[23:22:23] + 1802240 bytes downloaded
[23:22:23] + 1812480 bytes downloaded
[23:22:23] + 1822720 bytes downloaded
[23:22:23] + 1832960 bytes downloaded
[23:22:23] + 1843200 bytes downloaded
[23:22:23] + 1853440 bytes downloaded
[23:22:23] + 1863680 bytes downloaded
[23:22:23] + 1873920 bytes downloaded
[23:22:23] + 1884160 bytes downloaded
[23:22:23] + 1894400 bytes downloaded
[23:22:23] + 1904640 bytes downloaded
[23:22:23] + 1914880 bytes downloaded
[23:22:23] + 1925120 bytes downloaded
[23:22:23] + 1935360 bytes downloaded
[23:22:23] + 1945600 bytes downloaded
[23:22:23] + 1955840 bytes downloaded
[23:22:23] + 1966080 bytes downloaded
[23:22:23] + 1976320 bytes downloaded
[23:22:23] + 1986560 bytes downloaded
[23:22:23] + 1996800 bytes downloaded
[23:22:23] + 2007040 bytes downloaded
[23:22:23] + 2017280 bytes downloaded
[23:22:23] + 2027520 bytes downloaded
[23:22:23] + 2037760 bytes downloaded
[23:22:23] + 2048000 bytes downloaded
[23:22:23] + 2058240 bytes downloaded
[23:22:23] + 2068480 bytes downloaded
[23:22:23] + 2078720 bytes downloaded
[23:22:23] + 2088960 bytes downloaded
[23:22:23] + 2099200 bytes downloaded
[23:22:23] + 2109440 bytes downloaded
[23:22:23] + 2119680 bytes downloaded
[23:22:23] + 2129920 bytes downloaded
[23:22:23] + 2140160 bytes downloaded
[23:22:23] + 2150400 bytes downloaded
[23:22:23] + 2160640 bytes downloaded
[23:22:23] + 2170880 bytes downloaded
[23:22:23] + 2181120 bytes downloaded
[23:22:23] + 2191360 bytes downloaded
[23:22:23] + 2201600 bytes downloaded
[23:22:23] + 2211840 bytes downloaded
[23:22:23] + 2222080 bytes downloaded
[23:22:23] + 2232320 bytes downloaded
[23:22:23] + 2242560 bytes downloaded
[23:22:23] + 2252800 bytes downloaded
[23:22:23] + 2263040 bytes downloaded
[23:22:23] + 2273280 bytes downloaded
[23:22:23] + 2283520 bytes downloaded
[23:22:23] + 2293760 bytes downloaded
[23:22:23] + 2304000 bytes downloaded
[23:22:23] + 2314240 bytes downloaded
[23:22:23] + 2324480 bytes downloaded
[23:22:23] + 2334720 bytes downloaded
[23:22:23] + 2344960 bytes downloaded
[23:22:23] + 2355200 bytes downloaded
[23:22:23] + 2365440 bytes downloaded
[23:22:23] + 2375680 bytes downloaded
[23:22:23] + 2385920 bytes downloaded
[23:22:23] + 2396160 bytes downloaded
[23:22:23] + 2406400 bytes downloaded
[23:22:23] + 2412195 bytes downloaded
[23:22:23] Verifying core Core_a2.fah...
[23:22:24] Signature is VALID
[23:22:24]
[23:22:24] Trying to unzip core FahCore_a2.exe
[23:22:25] Decompressed FahCore_a2.exe (5509624 bytes) successfully
[23:22:25] + Core successfully engaged
[23:22:30]
[23:22:30] + Processing work unit
[23:22:30] Core required: FahCore_a2.exe
[23:22:30] Core found.
[23:22:30] Working on Unit 02 [November 20 23:22:30]
[23:22:30] + Working ...
[23:22:30]
[23:22:30] *------------------------------*
[23:22:30] Folding@Home Gromacs SMP Core
[23:22:30] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009)
[23:22:30]
[23:22:30] Preparing to commence simulation
[23:22:30] - Ensuring status. Please wait.
[23:22:40] - Assembly optimizations manually forced on.
[23:22:40] - Not checking prior termination.
[23:22:47] - Expanded 4827691 -> 24054549 (decompressed 498.2 percent)
[23:22:50] Called DecompressByteArray: compressed_data_size=4827691 data_size=24054549, decompressed_data_size=24054549 diff=0
[23:22:51] - Digital signature verified
[23:22:51]
[23:22:51] Project: 2671 (Run 44, Clone 22, Gen 134)
[23:22:51]
[23:22:51] Assembly optimizations on if available.
[23:22:51] Entering M.D.
[23:22:57] Using Gromacs checkpoints
[23:23:02] Multi-core optimizations on
[23:23:14] Resuming from checkpoint
[23:23:15] Verified work/wudata_02.log
[23:23:15] Verified work/wudata_02.trr
[23:23:15] Verified work/wudata_02.xtc
[23:23:15] Verified work/wudata_02.edr
[23:23:19] Completed 63228 out of 250000 steps (25%)
There's nothing wrong with that log file. It looks word for word like the one in mine, and I'm getting 8500ppd at the moment. Check that CPU and GPU are at 100%, check core affinities, priorities, etc. And maybe restart the VM. I'm not sure what it will do, but it definitely won't hurt.
I didn't see anything either (I'm not a log file expert though)
This makes me thing something is wrong outside the VM.
As the ATI GPU client needs a good percentage of one core to run at full speed .....
Try dropping it down the SMP client down to -smp 7 to free a core up for the ATI GPU client.
Then use something like WinAFC to lock the VM to the first 7 CPU cores and the GPU to the 8th CPU core.
That way the SMP client and the GPU client are not fighting over one core and both may run faster.
Luck ........... :D
Luck ........... :D
If he has the VM set to idle, could he not just set the GPU to slightly higher in the client to avoid all the extra steps?
They won't. Because of the affinities that you're advised to set in the guides, the GPU gets all the cycles it needs and the SMP takes everything else. Manually assigning the GPU client a whole core means the SMP client loses out on about 12% of a core, which as far as I'm concerned would make the SMP client worse off than if it had all 8 cores and had to give way to the GPU client.
Now in the VM console I am getting the line " attempt to access beyond end of device
hda1: rw=1, want =2097088, limit=2088387" What does that mean?
If this is a NotFred installation your running under VM, it's nothing major to worry about. I get the same on both of mine as well as others. I think it can be cleared with a VM reboot, but you'll continue to see it after a while.
How would I do that?
Manually, if you want. Bring up the task manager, right-click the Fahcore_11.exe process, and select "Set Priority". Normally people set it to "High", so that it takes precedence over normal system processes. Since it only uses one core, for dual-core systems and up it's no biggie, the system will function perfectly fine without that core. However, for single-core machines, I expect the performance hit to be more major. However, it means that the GPU client now takes precedence over everything else, maximizing ppd.
It's nothing to worry about. NotFred knows of the issue, and presumably he's working on a fix, but it doesn't affect performance in any way.
AARP - Did you ever get this Ati 5850 folding solid? If so, what kind of PPD are you able to get out of it?
The 5xxx series doesn't do well. Running stock clocks on my 5870 I average around 4.3k ppd.
That's better than any other ATI card.
Still, It's like having a Corvette and not being allowed to take it out of first gear.
Ahhh, okay. I was hoping that maybe the 5xxx series performed a bit better than previous models. Sure would be nice if ATi and Stanford would get together on that and provide a better client suited for the red team. I guess that CUDA has a huge advantage for crunching numbers, but there's a lot of unused potential out there with the ATi cards that could be put to good use (we *know* the horsepower is there).
It's not just the client, it's the scoring model aswell, it doesn't bode well for ATI
Now a more efficent client would boost the scores, and that would take a while, but it is kinda sucky that Stanford hasn't atleast adjusted the scoring a bit to help ATI
Posted via [H] Mobile Device
