PC
Asus P5K Premium/WiFi-AP Intel P35
4GB Crucial Ballistix DDR2 PC2-8500C5 1066MHz
INTEL E6600 Quad
ATI GRAPHICS
Power Enermax 600W
Scythe Ninja Plus Rev.B CPU Cooler with AS5
I am trying to refine the details on the bios, read the overclocking guide here but there is more details required that are listed in the bios.
Question???
is there anything else that should be change in the setting below?????? - lots of voltage on Auto, should it not set to some number???
AI Overclock timer - Manual
CPU Ratio Setting - 09.0
FSB Strap to North Bridge Auto
FSB Frequency - 333
PCIE Frequency - 100
DRAM Frequency DDR2 – 1066Mhz
DRAM Command rate - Auto
DRAM Timing control - Manual
Timming Info: 5-5-5-18-3-42-6-3-3
CAS# Latency 5 DRAM Clock
RAS# to CAS# Delay 5 DRAM Clock
RAS# PRE Time 5 DRAM Clock
RAS# ACT Time 10 DRAM Clock
RAS# TO RAS# Delay Auto
REF Cycle time Auto
WRITE recovery time Auto
WRITE to read delay Auto
READ to Pre time Auto
DRAM Static Read Control Auto
Transaction Booster Auto
CPU Voltage 1.2625V
CPU PLL Voltage Auto
FSB Termination Voltage Auto
DRAM Voltage 2.20V
NB Voltage Auto
SB Voltage Auto
Clock Over Charging Voltage Auto
Load line Calibartion auto
CPU GTL Voltage Ref auto
NB GTL Voltage Ref auto
CPU Spread Spectrum disabled
PCIE Spread Spectrum disabled
Thank you for your help!
INTEL E6600 Quad
ATI GRAPHICS
Power Enermax 600W
Question???
FSB Frequency - 333
REF Cycle time Auto
CPU Voltage 1.2625V
DRAM Voltage 2.20V
NB Voltage Auto
SB Voltage Auto
