newbie motherboard question
robman_rob
Hello
What is the difference between these motherboards?
Asus A8N-SLI Premium Socket 939 NVIDIA nForce4 SLI 2x PCI Express x16, Dual-Ch DDR400, Dual Gb LAN, SATA 3Gb/s, Dual RAID, 8-Ch Audio, Dual PCI-E
http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=007442&cid=MB.693
and
Asus A8N32-SLI Deluxe Socket 939 nVidia NForce4 True Dual X16 SLI 8-Ch Audio Serial ATA Raid, IEEE, Dual GB Lan
http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=008669&cid=MB.693
is it the deluxe can handle 2x sli at 16x speed while the premium can only do 2x sli at 8x speeds?
so the deluxe is better in the long run if u want 2x video cards?
but for single card there is not differences ?
how much faster is it in dual card configuration? .... 2x faster? :p ?
It's no faster if you're only using one card as far as I know. It's just that with the first board, if you have one card it is x16, but two cards split that to x8 and x8. The second board is "true" PCI express x16, so one card will be x16, and two cards will still be x16 each.
So, no, one card in the "true" board would not be x32 if that's what you're thinking.
edit: I should say though, that I haven't looked at benchmarks of the TRUE board, so I don't know if it is actually any faster. My guess is that it really isn't since most cards don't even use the bandwidth afforded by an agp slot.
the A8N32 has better power conditioning as well, IIRC.
but yes, the main difference is the ability to use two x16 cards in SLI at x16 each.
