Newbie Hard Drive Question...
for one, i cant recall HDD's haveing a "write speed". anyway read is how long it takes to find the information and access is the time it actually takes to load the information
I might be mistaken, but I think you may have the definitions reversed.
think you meant seek instead of read
seek time of a hard disk measures the amount of time required for the read/write heads to move between tracks over the surfaces of the platters
Access Time = Command Overhead Time + Seek Time + Settle Time + Latency
start here
General Notes On Performance Specifications
also
As the Disk Spins @ Lost Circuits
specifically: II Averages, Seeks and other Paradoxes
