thecodemeist3r
- May 31, 2008
I'm new to audio systems, and as such this is my first audio build.
This is what I am planning to get:
Wharfedale Diamond 9.1 bookshelf speakers
or
Wharfedale Diamond 9.5 Black
As for the speakers, they are what are currently available to me, that are from decent brands.
As for the amp, I choose this one, do you guys know of it? Good, bad?
TRENDS TA 10.1 WONDER MICRO AMP
This is where I am a little confused. Do you plug the speakers into a amp? then plug the amp into the receiver?
But cant you just plug the speakers straight into the receiver?
As for the receiver, I don't know what to look for, it would be great if you guys could point me in the right direction.
Cabling: the quality of the wires/cables can impact on the quality of the sound produced, correct? What should I be looking for in terms of quality audio cables?
I'll be connecting this to my computer via SPIF/coxial output from the motherboard.
I know my own research was pretty minimal before coming here, but if you could bare with me
or
