hi, new to ssf and pc builing in general (though i have replaced every compenent in a pc at some point or another). Built everything fine powered up ok and installing windows, got to setting up networks then got a blue screen saying windows had shut down to protect the pc make sure any new hardware etc was installed properly, ive had this screen before, usually fixed by a reboot, so i rebooted, now everything powers up but nothing appears on the monitor, tested monitor and graphics card and both function fine, hdd and dvd both have power and appear to be functioning. any suggestions on other things i should try or what might be wrong?
edit:
Samsung SM-913N 19" LCD Monitor
Shuttle XPC SK83G - AMD 64 (Socket 754)
Elixer 1GB (2x512MB) PC3200 184pin DDR
Western Digital Caviar Special Edition 250GB 2500JB ATA-100 8MB Cache
AMD Athlon 64 3400 Newcastle 130nm (Socket 754)
LG GSA-4163BA 16x16 DVD±RW Dual Layer ReWriter
GeForce 6600 256MB DDR TV-Out/Dual DVI (AGP)
edit:
